Results 1 to 10 of 10
    d2mike's Avatar
    Jun 2010
    Europe
    Default Audi A4 RB4/RB8 wiring dashboard -> engine ecu
    Hi guys,
    I have to simulate a complete immobilizer system on the bench. Therefore I need to know on which pins the dashboard communicates with the engine ecu!
    I think the communication happens via CAN Low/CAN High but I'm not sure.
    Thanks for info.
    Cheers,
    d2mike
    Shmortz's Avatar
    Apr 2010
    in the middle of nowhere
    32 pin green dashboard connector
    pins 18,19 - GND
    pin 2 - 30
    pin 3 - 15
    pin 12 - CAN L
    pin 13 - CAN H
  3. The Following User Says Thank You to Shmortz For This Useful Post:
    synkrotronic (7th March, 2016)
    d2mike's Avatar
    Jun 2010
    Europe
    Quote Originally Posted by Shmortz View Post
    pins 18,19 - GND
    pin 2 - 30
    pin 3 - 15
    pin 12 - CAN L
    pin 13 - CAN H
    So I connect - in this case EDC16 - CAN Low/High (Pin 66, 89) from engine ECU with CAN Antrieb Low/High (Pin 12/13), right?
    Shmortz's Avatar
    Apr 2010
    immo communication is between dashboard and engine ECU via CAN bus
  6. #5
    d2mike's Avatar
    Jun 2010
    Europe
    Thank you, mate.
    Should work for communication between dash and engine ecu:
    All other pins/wiring are self-evident.
  7. #6
    Shmortz's Avatar
    Apr 2010
    you may also need to connect engine control relay, or connect directly the power on ECU pins after the relay...
  8. #7
    d2mike's Avatar
    Jun 2010
    Europe
    Alright. Thanks a lot.
    I'll try and report tomorrow.
  9. #8
    yugo45's Avatar
    Apr 2010
    RB4/8:
    Blue connector:
    31 - Immo coil pin #1
    30 - Immo coil pin #2
    Green connector:
    3 - terminal 15 positive (12 volts)
    2 - terminal 30, positive (12 volts)
    18+19 - terminal 31, earth (ground)
    23 - self diagnosis/K-wire (K-line)
    13 - Can-H
    12 - Can-L
    EDC16:
    12V = 18,5
    Ground = 1,2
    K-Line = 72
    Can-H = 89
    Can-L = 66
    OBD:
    4+5 - Ground
    7 - K-line
    16 - 12 volts
    14 - Can-L
    6 - Can -H
    All 3 components Cluster , ECU and OBD needs to be connected ,plus you need to have immo coil and key if you want to do any programing.
  10. The Following 3 Users Say Thank You to yugo45 For This Useful Post:
    alclot (26th November, 2018), capi (12th March, 2020), mcgywer (12th April, 2013)
  11. #9
    d2mike's Avatar
    Jun 2010
    Europe
    Worked perfect!
    Thanks mates
    Cheers
  12. #10
    DK Veteran ghostridersa's Avatar
    Nov 2011
    Great info, thank you.
