hi i have been trying to initialize a usb stick in the solo for epg only, the problem is it gets to 99% then i get the failed message, i have tried 7 different ones today without any luck, has anyone got this to work and what make of usb stick are you using...thanks in advance
thanks for the reply but the problem is i cant initialize the stick it goes to 99% them fails tried 7 so far...cheers
Once you have done what mdt says all you have to do is configure and set up epg. Forget about what you are trying to do. hth
ok thanks will give it a try...cheers
still having problems it seems it is only some of the epg is loaded not all, no sports epg but have movies epg..any info much appreciated...cheers
What image are you on? Then we can get you sorted.
hi its image 2.4
For Vix Format stick in computer>Insert into rear of solo>switch off then back on>press blue button go to vix>mount manager>set up mounts green button>left or right till you select media usb then save. Then menu>set up>system>epg>settings then select epg location to media usb press ok to save. Then go to crossepg>configure>set scheduled daily download>exit>select update rytec providers>update xepdb providers>exit after they update>select open tv providers>make sure you tick the one you want> To save press green>exit press blue button>select crossepg downloader and don't interrupt. hth
must be a problem somewhere as everytime it gets to the end of Parsing Events it freezes....
It sounds like you will have to to a fresh install of image.
thanks for your help i got the box already set up but the person i got it from sent me a file called vu folder inside is vu solo in that is
root_cfe_auto.jff
kernal_cfe_auto
is this what i need to put on usb stick to reflash it (can no longer contact the person who flashed it)..
the folder should be called vuplus and inside that is vusolo and inside that is cfe/jff ect. put the vuplus folder into the usb stick and shove it in the front slot with the stb switched off at the back then switch the box on and leave it alone untill you have a flashing green led on the front. i always give it 15mins to be sure. when its finished remove stick and re-boot box,regards mdt
DM800HDSE SIM 2.10. SSL84D OPEN-ATV ORBITAL 80CM/DARK MOTOR/IBU/53E-30W
done a reflash but the problem is still the same when it gets to parsing events the box freezes...cheers
