right i have followed the tut in the sticky, but i cant get the $ channels to work. got cccam 2.1.4 installed and vix image. any one had this problem and solved it. i have the cfg file in /etc.
cheers
cheers
sorry i installed this, enigma2-plugin-cams-cccam.2.2.1_1.0-r0_mipsel.ipk
The Vix cams can be found heremaybe better trying one of these first before anything elseCode:http://www.4shared.com/dir/wnyHV50A/VIX_CAMS.html
Last edited by satsmo; 5th December, 2012 at 11:26 PM. Reason: Coded link, please do so in future especially to off site upload servers containg CAMs
Have you enabled it in the menu ?
When he says 'Enabled' it he means have you activated it in the cam menu
That's correct it should be good to go then
im trying to move the vix cam into tmp folder but it keeps saying move failure. and i have the cccam.cfg in etc, is that correct? do i need to edit that depending what version vix cam i have?
cheers
here try this cccam2.3.0 its in .ipk form....extract and ftp to tmp folder then install it via the addons panel..
Last edited by satsmo; 5th December, 2012 at 11:28 PM. Reason: Removed direct upload to our server
