Results 1 to 12 of 12
    DK Veteran rachmach's Avatar
    Jan 2011
    Workshop
    Default PROBLEM WITH XPROG M clone
    hello freinds
    I was reading a fismodule for a radio with xprog m
    i connect 2 wire 12v power and one wire GND
    my xprog m touched GND and he has short circuit
    now i cant read any thing
    i want a help tor repair it
    tankh's in advance
    Jan 2011
    Workshop
    help me please
    mexanico1971's Avatar
    portugal
    have you open it and see if there is something burn ?!
    try to see if it read a 24Cxx or other thing ?!
    good luck !
    Jan 2011
    Workshop
    i have open it but there is no thing
    and i try to read many eprom and no succes
    portugal
    any led is blinking ?!
    do you measure if there is any current in the PCB ?!
    Jan 2011
    Workshop
    when i want to read it displays a message (device insertion error bad contact at pin 1.2.3.5.6.7.8 )
    I reverse the eprom but the same problem
    I tried with another XPROG and it work perfect
    Aug 2011
    check all zender diodes, and 5V and 3,3V stabilaizers. if all is good, your atmega is fried, but i think it will can be 5V or zender.
    Jan 2011
    Workshop
    OK my freinds how to chek it ??
    Aug 2011
    there are two 3 leg chips near power in, ech is there 5V and 3,3 V stability. then chek the diodes that are near the small 8x2 pin output, they all should not have 0 resistance.
    Jan 2011
    Workshop
    ok tankh's i wil chek and report
    universal technics's Avatar
    Egypt
    Do you need more info to repair ?
    Jul 2013
    Scotland/Poland
    Hi can somebady tell me how to repair xprog m? I have this same problem what RACHMACH when i try read 24c16 i have a error device insertion error bad contact at pin 5.6.8.
    If anybody have a solution how to fix this.
    Thanks in advance
