Page 4 of 4 FirstFirst 1234
Results 46 to 57 of 57
  1. #46
    Europe
    The flash chip is not protected. But you can only write the entire chip in boot mode since the main software does not allow you to do this.
    Galletto v54 and MPPS v18 can't be made yourself. I don't know of any other cheap solution. You can buy them from the usual Chinese webshops, I'd recommend MPPS v18 or newer since it's cheap and does not break as easily as the Galletto.
    How did you read and write the EWS? I don't think Galletto can do that? Anyway, if you post your dumps here we can try to fix them.
  2. #47
    Oct 2021
    Hawaii
    Quote Originally Posted by tomvleeuwen View Post
    Aloha,
    Here is what I have. The original ECU Bin, the broken EWS4.3 Bin, and the working EWS3 Bin that's being rejected by ECU. The EWS3 will show complete green in BMW Scanner reads the keys starter is enabled however the ECU(DME) blocks the EWS saying the code is wrong. The AK90 will not let me save the EWS4.3 Bin on the EWS3. So that's when I pulled the ECU opened it and started trying to get it in boot mode so I can flash it.
    If you can fix the EWS or the DME Bin somehow where it bypasses EWS that would work.
    Mahalo,
  3. #48
    kiszka's Avatar
    Quote Originally Posted by funflo View Post
    Aloha,
    Mahalo,
    ews 3 is not read correctly or is corrupted
  4. The Following User Says Thank You to kiszka For This Useful Post:
    brend (21st October, 2021)
  5. #49
    Oct 2021
    Hawaii
    Quote Originally Posted by kiszka View Post
    Aloha please find attached a copy of the EWS 3 read from AK90 done just now.
  6. #50
    kiszka's Avatar
    I still think this file is incomplete
  7. #51
    Oct 2021
    Hawaii
    Aloha,
    Can you send a bin that would normally be on a 2D47J chip... Ill flash it on, read it, add keys, then send back to see if you can match it to the DME. The file I sent is all I have. Its from a EWS3 HW01 SW03
    Mahalo,
  8. #52
    kiszka's Avatar
    Aloha,
    Mahalo,
    i think you need to buy another EWS
    or read processor with programmer
    I think making keys with this file doesn't make sense
  9. The Following User Says Thank You to kiszka For This Useful Post:
    funflo (25th October, 2021)
  10. #53
    Oct 2021
    Hawaii
    Aloha,
    I got another EWS 4.3 and flashed that and it appeared to sync but now the DME isn't letting the car start. I can no longer flash it either however I can read the flash from it. So I ordered a used DME on Ebay. Anyone know if I can flash it with a KDCAN cable as that's all I have at the moment. I believe it will take months for the cable to get here from China for Galletto v54. I was looking at the MPPS cable and that's in china as well. Any options would be greatly appreciated.
    Mahalo,
  11. #54
    Oct 2021
    Hawaii
    Aloha,
    So I got a another DME and I wonder if you or someone can provide me with a virgin EWS, virgin DME, and a EWS that will pair with new(used)dme. I'm attaching the new DME file, old DME file, and current EWS file. All pulled with Galletto 1260 and AK90
    Mahalo,
  12. #55
    Oct 2021
    Hawaii
    Can someone provide 4 byte password for ews if i upload bin?
  13. #56
    pepi's Avatar
    Yes of course.
  14. #57
    Jan 2014
    have the same problem. can anyone help me to replace the ews4.4 with an ews3? ive got here plenty of ews3 SW08 please
