Page 1 of 4 1234 LastLast
Results 1 to 15 of 56
    south africa
    Default bmw ews4 - to ews3
    hi, is this possible and can anyone help -
    i have a bmw x 3 with ews 4 on it. the ews is damaged but i read the 2L86d mcu and saved the info. i do not have another ews4 .
    i have a ews3 that is in good condition. can someone please convert the ews4 info so i can code it to the ews3 module.
    thank you
    siraaj
    Quote Originally Posted by drivesure View Post
    thank you
    siraaj
    you have a EWS4.4.
    You cannot replace a EWS4.4 with a EWS3, the interface between DDE/DME and EWS is different. Buy used EWS4.4 and copy your data.
    regards
    SP
  3. The Following User Says Thank You to Sir Pommes For This Useful Post:
    Meat-Head (20th October, 2021)
    bram380's Avatar
    Indonesia +628153111774
    Use ews3 hw03 sw08 uta or kostal:
  5. The Following User Says Thank You to bram380 For This Useful Post:
    folarinm (19th March, 2018)
  6. #4
    south africa
    hi bram, i put your immo dump on the ews hw03 and sw08. vehicle cranking now. will see if i can align the the ews with a friends autologic.
    Nov 2010
    Nigeria
    I have the same problem of ews4. I tried the ews 4 in a X5 and it cranked but in the X3 it did not I got another ews4 and used AK 90 to transfer the information to it and i have exactly the same problem. I tried to write a new chip and it said "data error"
    please is AK 90 modifyng the data? how do i correct this data error?
  8. #6
    Nov 2010
    Nigeria
    hi Bram
    this is the dump attached
  9. #7
    bram380's Avatar
    which type ews3 you need?
    61.35-6 905 667
    61.35-6 905 668
    61.35-6 905 669
    61.35-6 905 670
  10. #8
    Nov 2010
    Nigeria
    I have both
    61.35-6 905 668
    61.35-6 905 670
  11. #9
    bram380's Avatar
    here ews3 dump & realign dme-ews.
  12. #10
    Nov 2010
    Nigeria
    I tried with AK 90 and it says data error any suggestion on the kind of tool to use in writing. can i use ews editor?
  13. #11
    Nov 2010
    Nigeria
    Hi Bram
    Your inbox is full i cannot send pm to you.
  14. #12
    DK Veteran ghostridersa's Avatar
    Nov 2011
    I have 11 ews 4 units here with me down the road from you in Montague Gardens.
    thank you
    siraaj
  15. #13
    Nov 2010
    Nigeria
    Default EWS4 to EWS3
    Thank you so much the X3 was able to start after programming the ews3 with Progman
    Bram Rocks!!!!!!
  16. #14
    Hello. I have this EWS3
    61.35- 6 905 666
    HW03 SW08
    I need the dump.
    My dump is damage.
  17. #15
    koncimobil's Avatar
    Sep 2011
    soxxi
    PA Soft can not read/write ews mcu.
    Read ews3 mcu with programmer.
