Results 1 to 11 of 11
    Mar 2008
    Default Accessing oscam outside the network
    Is there a way of accessing my oscam webif using the internet outside of my home network?
    I have vu duo running vix
    Jun 2009
    Setup port forwarding, then once you know your ip all good. If you ip is dynamic then use dyndns dot com to get round that.
    Sent from my iPad using Tapatalk HD
    Mar 2008
    i have a ni-ip address that i use for server, i have opened the port in question then tried 192.168.XXXX.XXX but its not letting me access it from outside. i know the port is forwarded as i checked on canyouseeme site.
    DK Veteran Rodbouy's Avatar
    you will need to allow a specific IP in oscam.conf
    Not advisable IMHO
    Mar 2008
    ok, is there any other way of accessing it?
    V.I.P. Member dell_xps's Avatar
    192.168 etc etc not an internal ip address m8, surely it would be the ip your isp gives you :-)
    Quote Originally Posted by hitman07 View Post
    Safest way Id reckon is have something like logmein or teamviewer on a pc or laptop, then you can use a app or outside pc to login and connect that way.
    Out with that I dont think so as the webif needs to know what IP it allows.
    Mar 2008
    ok thanks a lot
    Mar 2008
    I got this working guts, thanks a lot
    Feb 2012
    Could you tell us how you got it working?
    I'd be interested to know.
    Mar 2008
    i changed the config in oscam.conf to 0.0.0.0-255.255.255.255
    then got the external ip of my machine and tried from diff location
    always make sure you have strong password on webif though. and remember to restart oscam after altering any settings in the files in order for them to take effect.
    let me know how you get on.
