True USB GQ 3X EEPROM Flash Chip Programmer Supports All Willem ZIF Adapters | eBay
and you will need this adapter for PSOP-44 if you want to read/write 400BB/800BB
http://www.ebay.com/itm/Willem-Progr...item2c582d5e51
Batronix is a better option IMO...good solid high quality, neither my programmer or adaptors have once failed me.
the willen programmer in no good ? gq3x is better ?
If It Helped Push Thanks
The original willem is too old. It's good but it's too old.
As you may have noticed, our chinese friends call this "gq3x" also as "willem usb programmer".
Actually I suggested it to you as at least it was tested by me on many 400BB/800BB chips and never failed (as programmer). Weak spot are PSOP adapters you must be carefull with them and always clear well desoldered chips to make good contact.
the GQ4X has never failed me once although i replaced zif with a gold plated type one
great wee programmer for very little money !
Today is the Tomorrow you worried about yesterday ......Was it worth it ?
i will suggest you top 3000. really good and stable...
I would recommend Beeprog.
Universal programmers | Elnec
I use batronix48, exelent tool.
I use Elnec BeeProg+ and Galep 5
WinOLS 5, FGtech, Piasini, Powergate M, Byteshooter, OptiCan Dual II, EVC BDM, VCDS, BeeProg+,Ktag, Kess V3, Autotuner, Bflash
Fileservice
no thanks no pass
So you see you can make your choice------
Love this forum
