Results 1 to 5 of 5
    Jun 2011
    Default fx35 app sensor problem
    hello friends
    i have infinity fx35 the car was perfect theowner would like to change the color so he remove the engine and return it back after painting the car it start but it would not accelrate more them 1500rpm and it give the attached fault code
    app sensor and ...
    so help plss to know what i have to do
    rideon's Avatar
    RO
    If you didn't sort it by now,grab a voltmeter get on your knees and check for 5v and GND at the APP connector....see what's missing...
    A failure will not appear till a unit has passed final inspection
    Jun 2011
    Any wiring diagram to check?
    rideon's Avatar
    RO
    Don't have anything now,but search on pdftown,think you will find there
    If the car came in without this fault might be a loose ground connection-you mentioned painting- just ceck ALL the ground straps and use some sandpaper on them
    rideon's Avatar
    RO
