Hi I need help please i tried to program a new key for golf polo 2007 but it denied , it accept just one of them i can't program 2 keys,
any one can help please
thx in advance
thx in advance
You are either not changing key value to 2
or you are not cycling keys correctly
[Adaptation - 10]
Enter 21 in "Channel Number".
[Read]
The "Stored Value" is the number of keys currently matched.
Enter a "new value" corresponding to the total number of keys to be matched, including any existing keys.
Any old keys are automatically being cleared. All keys, including existing keys, must be matched at the same time.
[Save]
[Done, Go Back]
[Close Controller, Go Back - 06]
Repeat the following steps until all Keys have been matched:
Switch Ignition OFF and remove Key.
Insert the next Key and switch Ignition ON.
The Immobilizer Warning Light will light up for ~2 seconds, wait until it goes out, indicating that the key has been matched.
Note: The above steps must be completed within 60 seconds after saving the Adaptation!
High and Dry
are you using the handheld k can it programms 1 at a time select the key slot
it can happens someone has tried to program keys with wrong pin and the immo is blocked, try to leave the ignition on for 45min, erase dtc on dash, switch it off and on again, leave it on for 6min and then without switch it off program the new transponders. Should work.
