speed of devolo home plugs
Results 1 to 7 of 7
    DK Veteran NICETOBNICE's Avatar
    Nov 2011
    Default speed of devolo home plugs
    Hi guys i have just been updated to 20 mb broadband speed from virgin media .
    speedtest shows my speed to be pretty much exactly that
    but when i do speed test thats connected to my pc that conects to the network through homeplugs the speed is barely 5 mb the home plugs support 85 mbps
    can someone tell me if this is correct ?
    Top Poster 03ahmads's Avatar
    Jun 2011
    Wink
    No there's something wrong there, not sure what.
    Shite Link King Shady's Avatar
    Dec 2010
    192.168.1.xxx
    85mb should give you a transfer speed of around 10mb per second its all bits and bytes and multiplying by 8 or dividing by 8 and i can never remember the difference between bits and bytes, but as a baseline, you should be getting actual speeds of 10ishmbps, the factor in stuff like power adaptors plugged into same socket as homeplug and that'll be the reason your getting 5mbps
    Jun 2011
    Had nowt but trouble with my homeplugs. Binned them off in the end.
    Seemed that everytime the combi boiler kicked in, it dropped the speeds to about 1mb.
    Nov 2008
    Here
    Just to add homeplugs can be hit & miss,certain factors have to be taken like,distance,buildings structure,wall thickness & other wireless gadgets...
    GastonJ's Avatar
    Dec 2009
    Get get around 78mb out of my Devolo's. There's a small utility that comes with them where you can check the speed of each one "Informer". Would be worth checking them out. Don't plug them into extensions etc.
    May 2018
    Yo al final los quité porque tenía muchos cortes, en cambio si me llegaba bien la velocidad.
    Saludos.
