Your KTag has two options for read: Slave or Master?
Hello
I have problem with my ktag clone. in slave(full backup) ver read and write ok, but if i want to read only flash (ex. sid 803) or micro (ex. edc17cp14) at end of reading 99% it write checksum error and every file is different. what i can do to read and write good in master ver.
BR
unar
On genuine tool it is normal for that error to appear when it knows it will not be able to make write (e.g. due to lack of checksum) and when this happens the saved reads are always rubbish.
ok solved, works ok, in soon time I will write how to solve this problem
BR
unar
Solution is very easy.
If You have problem with checksum when R/W only flash, Your OS dont have C++ library. Two way:
- download C++ libarary from net -> instal it
or
- download from alientech website ksiute 1.85 -> install it, it will install C++ automatically -> remove dir C:\KSiute -> Replace it with KSiute dir which You get from Your clone supplier -> restart WIN -> be happy with Your master ktag.
Solution tested and works on 3 computers.
DONT START KSIUTE WITH YOUR CLONE BEFORE YOU REPLACE KSIUTE DIRECTORY!!!
I think it is helpful and make less stress for ktag clone users.
If I help You make thanks
BR
unar
antonypaul (31st October, 2014), arielcom (8th May, 2018), bawareca (20th February, 2015), bmotor60 (27th October, 2023), BMWS1KRR (5th December, 2016), cedi (14th August, 2013), cklair (27th December, 2014), datapage (12th April, 2014), euroscan (5th April, 2013), Fallen (8th October, 2014), izmir35 (18th March, 2019), jirkamarketa (24th August, 2013), jorko (16th June, 2016), ljamert (13th October, 2023), makas (26th August, 2013), mauronow (27th October, 2014), mimodiag (12th October, 2018), nanux (28th February, 2015), prusony (24th September, 2014), Toutancamon (25th September, 2018), wflseba (3rd January, 2015), YASS59 (11th May, 2020), ypiter (15th January, 2017), zladzejus (15th April, 2016), Zohar (4th May, 2013)
can you paste link to ksuite 1.85
not on alientech site
thanks a lot
i install c++ library of microsoft and same problem error chekcsum 99%
any solution please friend.
euroscan1 (5th October, 2013)
you must install c++ library 2005,2008,2010
You want say that you must install the tree c++librarys 2005,2008,20010?
2005 sure you must install
is it ok for every users of KTAG clone?
the only library needed for solve this problem is c++ redistribuitable 2005 sp1 ver 8.0.61001
ProTuner since 1999
Hello,i have the same problem my tool save Crypted maps file,can you tell me did you fix the problem and post a link from where i can download C++ to try if will help?
c++2005 and net framework 2.0 then vorked for me
