Results 1 to 4 of 4
    Dec 2012
    Default Total newbie and Ive cocked up
    Hello all
    Ive recently bought a skybox F3 and thought Id try it out and start messing with stuff I know nothing about "bad move"
    I downloaded one of the firmwares available latest one and I updated my box but now I have no channel list plus I have no
    Camds setup button anymore to type my server settings into
    Please someone tell me it is easily rectified as the box is like a foreign language to me at the moment
    Your hopefully
    cad12
    maca's Avatar
    Feb 2009
    liverpool
    Nov 2008
    Default not to panic
    ,,, when you put new firmware on, that deleted channel list,, easy fix,, just download tp pro list for skybox f3 and install same way as firmware,, when you open up, upgrade,, change image file to missc file,, ie scroll right,,,also hidden menu,,enter menu,,,, 6666 or 88888 should open up camd settings
    P&D's Avatar
    Quote Originally Posted by cad12 View Post
    Hello all
    Your hopefully
    cad12
    Hi Cad 12
    Follow jcbman40 to get them back so you can see the camd settings will come back
    then follow this link 2nd post in the listing step by step setup guide to get the channels back
    http://www.digital-kaos.co.uk/forums...ularly-260273/
    or download aj channel list .... AJ's List 8-12-12.zip this can be downloaded form the link above
    then follow his info
    How do I put this list on to my box?
    Firstly, before any upgrade you should always backup! Once you've done that;
    Unzip AJ's List XX-XX-XX.zip with a program such as winrar & place the TP_PROG.DBS file onto the root of your USB drive.
    In the Openbox menu delete your current channel list by going to the "Edit Channel" tab & selecting "Delete All".
    Staying in the menu navigate to the "Tools" tab then "Upgrade by USB", change the upgrade mode from "Image File" to "Misc Files" then "Select & Upgrade" & select "TP_PROG.DBS" then press yellow, if all done correctly it should begin to upgrade.
    Once the upgrade has completed restart your box & voil
