reflash mpc.... read and write again
Hello.This is the story : So I tried to make some mods on a MB Sprinter 2007 year.Read original file with MPPS, all ok.After modifying the file, saved, checksum corrected, try to write file with MPPS, at 100% it gives an error, saying Conditions not correct.tryed to re write the original file back, same problem.I opened the ECU, tryed to write the original file back with BDM , it says everything ok, but the car won't start.It doesn't even turn the engine.If anyone has ever had this kind of experience, advices are welcomed, thanks.
after reflash mpc, read the whole file ? mpc + m58b and write or ? ....
could someone please clear this out ? read and write, what ?
checkum after unsuccessful read-write are not stable.they are one solusion.write original file and scn.
so you are saying to write the original file I read with MPPS ?
you need write ori file back and hope that mpps not **** whit the file the renew ecu whit abrites and code to car again das will allso do the job to say you are en deep water i think hope you get it fixed
no use guys.I tryed orig files, checksums, everything.Any other oppinions ?
1. How did you open the ECU?
2. File read by BDM and MPPS are diffrent. You need ori flash BDM read.
Read all contents with BDM and upload here. We will take a look on it..
Magicmotorsport Flex Full, Magpro2, Swiftec, Winols, full ETL, Carprog and others....
when you crash ecu with mmps ...
you need to read bdm before you write
then you need to marry the bdm file and the mpps file
to make a bdm file (because in quite 75 % of mpps file should been empty that's why you need to do so ...
Ok, so :
#1 is the MPPS read who was read to 100%, without problems.
#2 is the bdm original file read AFTER the write with mpps went wrong.
#3 is M58BW016XB read after the failure writing.
#4 is mpc563/4 after the failed writing with mpps.
All in the file attached below.
Does anyone have a original bdm of this ecu to try that too?
Try this, restored the bdm file with a serial read from CMD.
Your MPPS original was already modified for a DPF off mod of some kind?
