bay FGtech2 (galleto2) for this car it is be bettor and not coust big money
Hi all,
which equipment is able to read/write Ford (2010) 0281014989 EDC16C34?
But this is not standard EDC16c34! Normally is in EDC16c34 MPC-processor (MPC562). And this new version has SC667034-processor.
P.
FGtech2 read/write this ECU through BDM,BootMode or CAN/K-line ?
... this ECU have not Tricore ... have you read/write this ECU?
I need 100% information, if FGtech2 read/write this ECU.
I working with obd for thia ecu not have problem with my galleto.
i read c4 with same ecu via obd with can protocol without problem
cmdflash
optican
galleto
etc
etc
they all read it obd
but warning take car of your injector codes you can loose them !! make sure you read the codes before to been able to install codes back easily
There are versions of new EDC16C34 that cant be read by OBD,only BDM
ECU Tuning, DPF and FAP remove,EGR remove, Flap remove,DTC remove,Dyno tested files!!!
i cant,becouse i not have FGTech,i use other tools but you can ask FGTech support if will be ok or no!if you use clone tool,better not touch this ecu and send client to other tuner that can do this
is there someone, who can 100% confirm, which equipment is able to read/write this ECU (by BDM or Boot mode)? Something like FGTech2 or K-Tag?
Many thanks in advance
Why so panic. This is usual ECU. In witch car is it in?
FGT2 is working this ECU 100%.
You can also read with MPPS but I have bad experience on Ford vehicles. MPPS can brick the ECU during writing.
The best way is always BDM readout, you can brick the ECU even with best flashing tools, its happening also.
Just don't panic.
BR
__________________
If You Like My Post
Please use the button on the LEFT side and the button on the RIGHT side.
Tuning, EGR, DPF, AdBlue, DTC, TVA, Speed Limit, Immo...
I'm easy ... no panic
It's Ford Fiesta 1.6TDCi MY 2010 - 0281014989
But this is not standard EDC16c34. Normally is in EDC16c34 MPC-processor (MPC562). And this new version has SC667034-processor.
I want to buy new equipment to read/write ECU (by BDM or boot mode) ... something like FGTech or K-TAG and i'm not sure, which equipment can read/write this ECU.
