Ok, at least which model/operating system would have helped more and ofc posting in the right section.
The most ideal situation would be backup your current drivers, assuming you are installing the same os, you could do this using a tool like -
http://sourceforge.net/projects/drvback/
failing that install the operating system you intend the machine to run.
then download This will also update any older drivers you may have.
If your still stuck more info the right section, will probably get noticed more and get you a response you can work with
