willyboy28 (17th April, 2022)
you car must been ml400 not ML420 ml420 use bosch ecu ...
I'm also very interested in solution to disable EGR on temic ecu.
PM me pls if someone have working solution.
Regards,
Alex
Is posible read flash in circuit?or inteface??my unique solution is desolder flash and read in programer.Thanks and regards
Hello friends,happy new year to all!Other day i read flash,please i need help for egr off.Thanks and regards
Please i need egr off is urgent for me.thanks
have you tryed to flat out the egr maps ?
Hi friend.I have not tried, my intention was to disable the switch egr cartography.Is posible in ecu temic??Thanks and regards
i think you can forget switch there isn't lot info about temic adressing ...
I view maps injection and rail presure,are similars maps in the ecu bosch.I think the egr switch is similar to bosch ecu, but must be double as carrying two egr.
even siemens rail pressure maps are quite always the same only factor change with siemens
but this ecu has less maps
Something can be done to egr off, nothing is impossible .... someone will have found a similar case?
I had ML 400 CDI and P0403 error. I can help you close EGR, if it isn't too late.
Can you help me close egr? I have problem with both egr valves on the same car but my ecu is temic crv1.0
