Lets start from the beginning.
So your thinking on buying a new Wii so you don't have one at the moment?
As said all new Wii's are 4.3 so LetterBomb will ONLY softmod it. The Wii must have an internet connection for this to work.
A typical 4.3 sysCheck after softmodding, this is one I did this August.
You will see there are 17 stubs which you have to install certain wads to remove the stub word so it only shows 5.sysCheck v2.1.0b18 by Double_A and R2-D2199
...runs on IOS58 (rev 6176).
Region: PAL
System Menu 4.3E (v514)
Drive date: 2008.12.18
Homebrew Channel 1.1.0 running on IOS58
Hollywood v0x21
Console ID: 142223625
Boot2 v4
Found 70 titles.
Found 46 IOS on this console. 17 of them are stub.
IOS3 (rev 65280): Stub
IOS4 (rev 65280): Stub
IOS9 (rev 1034): No Patches
IOS10 (rev 768): Stub
IOS11 (rev 256): Stub
IOS12 (rev 526): No Patches
IOS13 (rev 1032): No Patches
IOS14 (rev 1032): No Patches
IOS15 (rev 1032): No Patches
IOS16 (rev 512): Stub
IOS17 (rev 1032): No Patches
IOS20 (rev 256): Stub
IOS21 (rev 1039): No Patches
IOS22 (rev 1294): No Patches
IOS28 (rev 1807): No Patches
IOS30 (rev 2816): Stub
IOS31 (rev 3608): No Patches
IOS33 (rev 3608): No Patches
IOS34 (rev 3608): No Patches
IOS35 (rev 3608): No Patches
IOS36 (rev 3608): No Patches
IOS37 (rev 5663): No Patches
IOS38 (rev 4124): No Patches
IOS40 (rev 3072): Stub
IOS41 (rev 3607): No Patches
IOS43 (rev 3607): No Patches
IOS45 (rev 3607): No Patches
IOS46 (rev 3607): No Patches
IOS48 (rev 4124): No Patches
IOS50 (rev 5120): Stub
IOS51 (rev 4864): Stub
IOS52 (rev 5888): Stub
IOS53 (rev 5663): No Patches
IOS55 (rev 5663): No Patches
IOS56 (rev 5662): No Patches
IOS57 (rev 5919): No Patches
IOS58 (rev 6176): USB 2.0
IOS60 (rev 6400): Stub
IOS61 (rev 5662): No Patches
IOS70 (rev 6912): Stub
IOS80 (rev 6944): No Patches
IOS222 (rev 65280): Stub
IOS223 (rev 65280): Stub
IOS249 (rev 65280): Stub
IOS250 (rev 65280): Stub
IOS254 (rev 65281): BootMii
BC v6
MIOS v10
Report generated on 2012/08/31.
Download sysCheck and add it to the SD card. All applications that run from Homebrew have to be in the apps folder in their respective sub folders on the SD card. Put the SD card back in the Wii and run sysCheck from Homebrew this will make a sysCheck.csv on the root of the SD card which is needed for the next part.
Download ModMii6.1.5 and run it from Windows. On the main menu type in SU and type in the location of the sysCheck.csv. Its easier to put this on the root of a drive as it saves typo's.
That will download all wads and apps that are missing into a COPY_TO_SD sub folder. Add all files and folders to your SD card and run Homebrew with the SD card inserted.
First of run IOS236 installer from Homebrew and install IOS36 as IOS236. Come back out and run Multi-Mod-Manager and select WAD Manager this will default to the wad folder install all wads in there. Watch for the Installed OK message after each one. If any don't install just try them again.
Now ModMii only installs 2 d2x v8.0 wads so you may as well install all the others. d2x v8.0 final pack
You need to install PriiLoader 0.7 to block online and disc updates. I also disable the 'A' prompt on startup.
After you've installed all the wads listed you can run a sysCheck again and it should say 5 stubs which is ok.
You can install the forwarder wads so that app will show on the Wii menu. I will tell you that after its softmodded and all the wads are installed.
