Results 1 to 5 of 5
Hybrid View
    DK Veteran dimitar22's Avatar
    Jan 2009
    Default MAN TGA ZF ASTRONIC PROBLEM
    I have problem with MAN TGA ZF AStronic gearbox.
    The errors i get are:
    TCU 3145
    TCU 3147
    TCU 3154
    TCU 3155
    TCU 3150
    My first thought was the clutch, found broken springs on the clutch disc .
    Replaced the clutch disc ,pressure plate, bearing with genuine SACHS kit.
    But the error codes remained.
    It is difficult to engage in forward and revers.
    Any suggestion is appreciated.
    a little help.
    Jul 2018
    I'm a noobie and it wont let me view it :-(
    Oct 2018
    Default Not shifting up from 5th gear
    Quote Originally Posted by Cursor10 View Post
    a little help.
    Please can you resend the attachment? It wont open if I click on it
    Aug 2009
    Looks like low air pressure at the gearbox top by your fault codes -Try this:
  6. The Following User Says Thank You to blurty For This Useful Post:
    tom2222 (21st May, 2020)
