hi guys, and updated delphi 3/2012, have fileactivation.xml and I recognized vci, the problem is that I always ask update firmaware and will not let me diagnose any car, does anyone has passed this problem?
update the firmware.
can you tell us, how you reflash memory?
on pcb or separatly?
thanks!
hello, i have similar problem with my old autocom, im using 2011.1 version and after laptop upgrade autocom software tells me that firmware in tester is not up to date.
When trying to upgrade firmware it thows error.tried to change serial nr. from 30250 to 30221 with tool.exe but result is same.
Maybe my serial is blacklisted? what serial should i use? or maybe i should try to upgrade firmware with newer version of autocom software?
or should i manualy upgrade firmware reflashing it by programmer?
waiting for suggestions! thanks!
try to solder again flash memory .if not work then programm flash with a programmer with a updated version.![]()
Hi all, I have the same problem I can not update the firmware Update the device, it tried everything to change the serial number of the probe is useless, what could be done?
ive tried to reflash flash memory with programmer with 2011.1 version found here on dk result is same: when trying to test says needs to update, when try to update gives error![]()
thanks!
I have single board VCI and did not know what kind of flash memory has but the update process was made by software when I press the update button.Originally Posted by aady3333
If you need to make update to the device you need to meet the following requirements
1. USB cable must be good quality, I had a case with a programmer who did not want to work because of the USB cable, which had a communication but not enough to programm
2. Best memory from AMD and BSI manufacturers
3. Markings on the processor is also important (so far I've encountered two different tags)
4. Construction of the hardware (so far I've encountered 4 different types) printed circuit boards are the same but the majority of the components are missing
hello
I don't want to write new thread so I'll write here.
I have autocom cdp + in silver- black package.
My question is.. if SN changer cannot connect with device is it damage?? When I was tried to change sn device was conected to car.
Whit my device i have 2012 02 relase soft but i dont have activator so i installed 2012 03 but software see autocom on com but can't connect (options search to):\
Where is my problem??
in software??
maybe can someone active my acom?? this files is from 2012 .2 relase cdp+!
thx for advice
regards![]()
I can help you but only if you want me to help you
All the questions should start from what car, what year, what engine is what fuel. What are the symptoms of the problem. Only then is what you know, what fault code, live data, what you have done.
I've just updated the firmware on both cars and trucks with clone (serial 100251) and sw 2012r3. It does not need to be in car if you can power it up on the bench. Basically I had pins 4 and 5 = GND and pin 16 = 12v.
I've just read a post on another forum saying the program can be internet updated to 2.12.3.2 and this updates the firmware to v1231. Has anyone had the balls to try this on DK?
V Series TMS470 / EEPROM data - encryption / decryption, totally pwned.
IEC 62056-21 - new discussion: sonsivri.to/forum/index.php?topic=60412.0
