Results 1 to 7 of 7
    May 2011
    Hungary
    Default Sharan 2008 FAP remove
    Hi all,
    could anybody help me to remove FAP/DPF from this car. I've tried to remove wit ECUSAFE 2.0 ,but it didn't works. The car is in limp mode and the dpf lights on cluster. There is no dtc with diag (because of ECUSAFE)
    ECU NR:ECU BOSCH EDC16U31
    0 281 012 696, 03G 906 016 JP
    I would be the best to remove manually (Winols...etc)
    Thanks in advance!
    Jun 2012
    La Coru?a - Spain
    Try this one Report please
    May 2011
    Hungary
    Hi, tomorrow I will test it!
    Is the diff. pressure sensor have to be connected?
    Thank you i advance!
    Jun 2012
    La Coru?a - Spain
    You can leave it connected, no problem
    May 2011
    Hungary
    Hi! The car runs well with this file, I hope that not for few days!
    Jun 2012
    La Coru?a - Spain
    hahahaha let's pray for it
    Thanks for report.
    vsanyi's Avatar
    Aug 2012
    please pass!
