hello best freinds i have a bsi from citroen berlingo model 2001
and i like to read the nec mcu into it i try it with upa but i can't
if someone can help me please.
Try this conectins
alefabi2006 (11th January, 2015), capi (3rd October, 2018), galaxy0634 (2nd January, 2019), gameiruz (5th January, 2014), HeXeN (29th August, 2019)
dont work on this dash 2001....only new model
Operated models:
1. Peugeot 207
2. Peugeot 307 from 2005- ...
3. Peugeot 308
4. Peugeot 407
5. Peugeot 607 from 2006-...
6. Peugeot 807 from 2006-...
7. Peugeot Partner III
8. Peugeot C8 from 2006-...
9. Citroen C2
10. Citroen C3 II
11. Citroen C4
12. Citroen C4 Picasso
13. Citroen C5 II
14. Citroen C6
15. Citroen Berlingo III
16. Lancia Phedra from 2006-..
17. Fiat Ulysse from 2006-
HELLO
use only this connection for upa only
diga dp3 enigma and nec programmer use another pin 11
be carrefull for connect pin 1 to 8 and 12
this picture work perfect!!
the tool for change the mileage via obd work only via can bus and the best is psa by smok!!work very quicly
use this link for buy the psa tool
and new update is available:: bsi continental!!!
http://diagcar.pl/STR_EN/xml/pdf/PSA_EN.pdf
Car Electronics
the xtorse is big sheet
29f001 (21st January, 2023), amlop (8th November, 2020), autoTkey (18th February, 2015), capi (3rd October, 2018), danielif (25th March, 2018), ELAB014 (12th January, 2015), gobe (19th March, 2015), HAMIZA (31st March, 2017), madaxe (17th September, 2015), martinracing (3rd January, 2015), pedro333 (31st July, 2018), pollito128 (20th June, 2014)
my freinds into the bsi it have NEC 780949 (100 pin) mcu please help me to read it with upa
Are you using Nec adapter for UPA?? I have read it with it several times
I tried to read this MCU with UPA.
Connected all wires, tried to connect as NYO4 suggests - pin 9 connection error
Tried to connect them how UPA suggests - pin 9 connection error
Tried every different options I found on DK - pin 9 connection error
What could be the problem here?
Hi mates,
I made same as post 7.
The UPA gives me baudrate capture error
Does someone know what?s going on???
THX
Andres Alonzo (18th February, 2021), autoTkey (18th February, 2015), claudio35 (12th January, 2015), HAMIZA (31st March, 2017), Hayssam1 (20th November, 2019), madaxe (17th September, 2015), mikajna (30th July, 2020), Nikola1309 (12th March, 2015), pollito128 (1st April, 2015), rodriguez9548 (24th June, 2019), satkingno (30th September, 2016), sl4ck (11th January, 2015)
No working for me. I have one yellow clone
http://www.digital-kaos.co.uk/forums...ut-nec-456726/
Hi, I use Etl Nec programmer + micro hooks for all nec procesor. For Berlingo bsi, 5 min job.
Best regarde
Vladimir
