Page 2 of 2 FirstFirst 12
Results 16 to 25 of 25
  1. #16
    Nov 2012
    greece
    working with yellow and red UPA ADAPTER
    Check contacts adapter (same problem I have had)
  2. #17
    Jul 2014
    hi newgeniehex
    thx for your info works ok with upa
    My problem was that my nec adapter was faulty
    I posted info to know how to solve the problem
    cheers
  3. #18
    Feb 2014
    Quote Originally Posted by newgeniehex View Post
    HELLO
    use only this connection for upa only
    diga dp3 enigma and nec programmer use another pin 11
    be carrefull for connect pin 1 to 8 and 12
    this picture work perfect!!
    the tool for change the mileage via obd work only via can bus and the best is psa by smok!!work very quicly
    use this link for buy the psa tool
    and new update is available:: bsi continental!!!
    http://diagcar.pl/STR_EN/xml/pdf/PSA_EN.pdf
    Car Electronics
    the xtorse is big sheet
    Quote Originally Posted by Mario3 View Post
    your adapter is probably not working, here you have a tutorial how to repair the upa adapter for nec.
    if i helped thanks is below
    regards
    These two tutorials work. I have tested. Repair tutorial saved my NEC adapter - it wasn't working before. And the connecting tutorial helped too. Finally got the NEC working on UPA! Soldering the 1-8 cables is still tricky - be careful on them.
  4. #19
    Nov 2014
    Can somebody please share this info. I have 307 dash nec upd780973 need read/ program. My nec adapter is green and every time get baudrate capture error. Will happily pay for solution. Please email me Lehane87@gmail.com
    Thanks in advance.
  5. #20
    Jul 2016
    Can read it by obd the bsi with NEC processor
    Sent from my HTC 10 using Tapatalk
  6. #21
    rob h's Avatar
    May 2011
    I have this original programmer.
    UUSP-S (UPA-USB Serial Programmer-S)
    Black casing.
    I read that some use a reworked clone 78K0 HC9s12 adapter.
    Which should i buy? Red or green pcb?
    Only need it for 1 single job, and i am also considering a original adapter.
    Need it to read: Valeo bsi with nec 780949
    Xsara Berlingo Partner
  7. #22
    Trstenik - Thun
    Quote Originally Posted by rob h View Post
    Black casing.
    red or green are the same shit ,same pcb errors,,not working at all and need to be reworked ,both.
    better buy original adapter
  8. The Following User Says Thank You to mikroel For This Useful Post:
    rob h (11th February, 2019)
  9. #23
    Feb 2014
    There is a rework tutorial on the first page of this thread, thanks to Mario. It is (very)easy to do and after that it is unstoppable
  10. The Following User Says Thank You to autoTkey For This Useful Post:
  11. #24
    Trstenik - Thun
    unfortunately it isn't enough for many adapters which are coming from china .
    There are many different version of green and red Chinese adapters .
    for example
    for these two models
  12. #25
    Feb 2014
    The adapter from the pictures from the FIX from Mario looks the same to me, like both red and green (same position and same amount and type of components). Color of the PCB is just that - color. Doesn't mean anything.
    1.jpg\
    Anyway - for me it is easy fix and works 100%. For you - it is your opinion and I don't know if you tested it?
