Results 1 to 9 of 9
Thread: Which Xbox 360
    Feb 2011
    Default Which Xbox 360
    Hi all I'm looking to get my son a Xbox 360 to use with backups of his originals, which would be the best version to go for & the easiest to mod? thanks in advance
    Quote Originally Posted by w13dle View Post
    the old phat version is what i got as firmware is done 1st before the slims and you dont need replacement pcb to flash the old phat ones saves money but the choice is yours. check out c4eva on google for firmware updates as that is main place to find out about what latest firmware is
    Feb 2011
    Quote Originally Posted by thelips View Post
    thanks for heads up i'll check it out, I'd prefer a slim but there seems alot more involved, I think I'll keep my eye out for a already modded phat version, cheers
    cunny's Avatar
    Jan 2009
    The Shoutbox
    You can get slims dopne as low as ?25 but you be lucky to have the mcix chipset or if you kno someone really good at kamakize hack if you got a winbond
    If you want a slim, get 1 pre modded or you could be waiting for LTU and a replacement PCB
    Feb 2011
    It seems a better & cheaper option as said to get one pre modded, I've been offered a couple:- a brand new 4gb slim RGH the drive isn't flashable yet or a Slim dual nand with the demon tx installed & flashed drive, which would be the better of the two?thanks
    Sep 2008
    dual nand with demon would obviously be better.
    if it's rgh, i don't see much benefit in flashing the drive if you're keeping it in that xbox. of course you would flash the drive anyway while doing the rgh, but you won't really use it much... unless you have big stack of backup dvd's. best to stick everything on a hdd and run it of there.
    dual nand is useful if you intend on using xbox live. if you're not going to be using live or buying the gold subscription, not much use in it.
    also it would dend on how much it costs. how much for just the 4gb rgh?
    cunny's Avatar
    Jan 2009
    The Shoutbox
    I'm running a demon phat box and have returned the drive back to stock for reason I cannot be bothered flashing to stock on each retail update.
    You also have the option of link in fsd that is a new multiplayer option.
    Rgh opens up so many new avenues of homebrew and other options
    Sent from my GT-I9300 using Tapatalk 2
    Feb 2011
    The 4gb slim RGH he said is brand new & the drive cannot be flashed yet 150, & for the slim with dual nand 200,
    If Its easy enough to put everything onto a hd like you say there doesn't seem any point in using the drive & having to update everytime, Live access isn't essential as we can use the ps3 online, I've checked out the link in fsd you mentioned which sounds a good alternative
    Sent from my HTC One X+ using Tapatalk 2
    Feb 2011
    being a new 4gb model are these not compatible with the dual nand Demon should I want this fitting at later date?
