you file is tuningprotekcion
wen read id of ecu mpps v16 hawe neu modul and tels you is ecu protekted or not
Hello.
Please help me.
I did read and write obd with original Galletto an Audi Q7 2009 EDC17CP04 0281015868 , and after write doesnt start anymore. After i did read in boot mode and write again in boot, but doesnt start. I have ori reads, and i file from other Q7 same ecu, but i did try as all i can, and doesnt start.
I add q7-edc17 that is original read obd and later write obd, boot read
and add other q7-ok that is original read from same ecu other car working
Many thanks in advance
Try this fixed file, don't fix CS after writing, two monts ago i damage A4 2.7TDI 2010 the same way, and later fix it
This is your file
this is fixed A4
yes it's tuning protection or clone tool can also brick ecu's
so my galletto2 may kill these ecus.
MAGPRO X17--AT-200--SCANMATIC BENCH--PCMFLASH--MITSUBISHI MUT-III---OPENPORT 2 MMC FLASHER
SOLUCIONATED. FINALLY FLASH AND EPROM CORRUPTED. Tabster send me new files write and starts..... THANKS
if such problem, dealer can solve it with about 15euro/programming
How can dealer solved this, progrmm a new sotware version ?
whats country where diler charges 15 euro for ecu reflashing, programming.
he killed ecu because he flashed obd ecu which is tprot7
looly (9th April, 2014)
We one time get this problem to audi A4 1.8T petrol.
master read with mpps V12 obd and after started car all be ok!
after he for save read one more time but use galleto2 clon china.
and car started 1 time and after stop!
and write fault tuninig protection.
we find same gay who recalculated EEPROM and after car working fine!
