Results 1 to 11 of 11
    Oct 2012
    Default INMO OFF EDC 16 BMW 530 help please
    Hi all.
    can someone help me to remove this ecu off Realty?
    can be removed?
    thank you very much for your help.
    read attachment via BDM.
    _flash
    _eeprom
    _mic
    bearheroes's Avatar
    Dec 2011
    try to synch
    isn 3F EF
    Oct 2012
    Quote Originally Posted by bearheroes View Post
    try to synch
    isn 3F EF
    hello, I tried to sync but does not work. ews error code manipulation.
    isn? which means?
    thank you very much.
    bram380's Avatar
    Indonesia +628153111774
    read mcu from ews.
    post here thi dump.
    ews need to reset the rolling code.
    Oct 2012
    Quote Originally Posted by bram380 View Post
    read mcu from ews.
    post here thi dump.
    hello I attach eeprom and flash memory of CAS 2 white, I hope I can help.
    Oct 2012
    help me please.
    bram380's Avatar
    Oct 2012
    thank you very much, in a moment I'll be testing.
    Oct 2012
    hello, I tried the alignment after writing in the DDE with the file you sent me.
    in the CAS module fault code, but DDE (EWS interface error 4A41) fault code is present.
    you think?
    from already thank you very much.
    Oct 2012
    help me please
    bearheroes's Avatar
    Dec 2011
    try to change cas and keep your dump.do again all the process.
