Results 1 to 6 of 6
    Dec 2012
    Default One dish, Two LNB, Two recievers?
    Can you please tell me if this set up will work?
    Room 1: 28.2 on sky box
    Room 2: 28.2 and 10e on dreambox
    Would it be possible for someone to be watching 28.2e channels in room 1 and somebody in room 2 to watch a different 28.2e or 10e channel without having to turn one box off?
    Nov 2008
    a sky box cannot operate a diseqc switch, so not sure how that would work as it may as well have its own direct feed from the dish anyway (like they normally do)
    digicon's Avatar
    Jul 2009
    It would be useless sending Diseqc data to an official receiver as it wont work you only need to take a feed from 28.2? east and one from 10? east to your switch connected to your dreambox
    Dec 2012
    Thanks, I've just placed an order for 1 switch, with your setup above, would i still be able to view different channels in the two rooms at the same time?
    e.g. Sky box: Sky channel & Dreambox: 10e channel
    or
    Sky box: Sky channel & Dreambox: 28.2e channel
    Revised setup:
    Would i need to buy a single lnb?
    Nov 2008
    twin or quad lnb on 28e and single on 10e
    switch is used for dreambox for both feeds, and sky box has direct feed from 28e
    each box can watch what it wants
    Dec 2012
    Quote Originally Posted by ramjet View Post
    Thanks for the help
