is locked by ecusafe
so how to read it by bdm?
BDM read should work
I made diagnostics with vcds but only error for egr thats why i wanted read it to disable egr..
Maybe someone else try to disable dpf but the new owner of the car dont know for sure so its can be locked by ecusafe.but if its locked possible to write it?
Or update at audi I think the easyer way and after I can handle by obd...
raptureready (7th June, 2016)
yes its more clear and i dont want to take out the ecu...
If the seed key is messed the dealer will not be able to re flash your ECU.
I have the same issue, only BDM readout, repairing seed key and reflash with BDM. But if you have messed eeprom then this will not help you. Then you have to adapt your eeprom too.
I have same problem at my car and I know how annoying is this.
BR
__________________
If You Like My Post
Please use the button on the LEFT side and the button on the RIGHT side.
Tuning, EGR, DPF, AdBlue, DTC, TVA, Speed Limit, Immo...
air123 (28th January, 2016)
how to repair seed key?and what do you mean messed eeprom?and how could its happaned to the ecu?
Someone have messed up with this ECU, thats for sure. Just readout with BDM and post it hire. We can help you then.
__________________
If You Like My Post
ok,thanks but first try to update at dealer and after see...
