I use the car Batery
Use another car sitting next to one being flashed with jump leads running across. Not ideal but its so hard to get a regulated supply for this purpose.. only found one seller and they wanted around ?450+VAT.
Sent from my HTC One X using Tapatalk 2
Yes it is hard to get a regulated supply, especially on the go but The running Engine from another vehicle is a good source. I'm going to fit and Anderson connector underneath the grill on my van and make a nice long set of these.
I use this:
Real engines don't need forced induction
Who needs a turbo when you have a stupidly quick naturally aspirated engine?
I use this
WinOLS 5, FGtech, Piasini, Powergate M, Byteshooter, OptiCan Dual II, EVC BDM, VCDS, BeeProg+,Ktag, Kess V3, Autotuner, Bflash
Fileservice
no thanks no pass
"I always tell the truth. Even when I lie"
"We Taking Over, One City At A Time"
Been Meaning to do this mod for ages, Search for anderson Connector Z
im going to now you have raised the issue, I flashed a Transit ST with a booster not long ago and the bat was flat as a witches Tit nearly after, I was lucky, Brings the headlights on when you Flash them OBD.
I use both !
for bench regulator power supply !
for OBD power charger !
Why you don't make it?You have some skills to do that?I can help you with power supply 0-24V and 3A (enough if you have battery on you car and it is also enough if you work on bench with ECU).
i need a medium priced solution to keep 14v and maybe 30amps constant, any ideas? iv got this
http://www.bauhaus-nautic.info/media...ort_8HKoV3.png
but not sure if its a constant supply
Your charger won't charge VRLA batteries very well... you will be there all day with that.
Voltcraft SPS 1560 PFC
a simple battery charger vuld be enough
