Results 1 to 5 of 5
    Default galletto boot mode question
    Just starting my experience with galletto.
    How to enter boot mode of proc. (using galetto correct sequence)
    I try read ME7.9.5 (C1) do it like tihs:
    1) connect like in pic pin 4 pcb to gnd and 6 to 13. (with 1K resistor)
    2) power supply to ecu.
    3) disconnect both (6 with 13) and 4 form gnd
    4) read file
    and got error.
    any idea ?
    Oct 2011
    share foto where is see manual conection
    Get push THANKS on right side button . . . . and add
    Photo.
    Question how to enter boot mode.
    Connect like in picture and power on 2-3s and disconnect both resistors ? after that i press read but error apear.... not in boot mode
    K line work because when i select driver citroen c1 etc. I can read ident of ecu via k lnie in "car" mode not "boot" I hope you knwo what i mean
  4. The Following User Says Thank You to kuti For This Useful Post:
    Hayssam1 (8th May, 2016)
    Bolzano
    maibe u are using the wrong k-line, on Galletto not clone the k-line is the green cable not blue
    cable and connection is ok because i'm able to communcate with ECU even write file to ecu but not in boot mode.
