Results 1 to 15 of 18
    Nov 2008
    ireland
    Default static IP Debian 5
    Hi all,
    I am wondering if anyone can help me with setting my IP to static on my debian PC. With putty and using the command nano /etc/network/ interfaces I can see and change the DHCP entry to Static. However after I reboot I cannot now access the internet.
    Is this a DNS issue and if so where do I set this up.
    Thanks in advance,
    Jul 2012
    Gothenburg
    Quote Originally Posted by philly View Post
    Hi all,
    Thanks in advance,
    Example:
    frd@cardserv:/etc/network$ cat interfaces
    auto lo
    iface lo inet loopback
    iface eth0 inet static
    address 192.168.1.99
    netmask 255.255.255.0
    gateway 192.168.1.254
    Nov 2008
    ireland
    Quote Originally Posted by zOOge View Post
    Example:
    auto lo
    Thanks for your reply.
    At the moment when I run this command 'nano /etc/network/interfaces' I get the following,
    # The primary network interface
    auto eth0
    iface eth0 inet dhcp
    address 192.168.1.127
    broadcast 192.168.1.255
    gateway 192.168.1.1
    I then change the dhcp to static and save and reboot. After doing this I cannot get on to the internet. I also noticed that at the moment my server is working in dhcp mode with Ip 192.168.1.101 however I am still getting the above which is 192.168.1.127 which is not the case.
    Confused
    digicon's Avatar
    I tried this when i ran debian 6 and it never worked, i did read that it can cause issues so i went with the advice od setting the static ip in the router itself. Just a Thought
    The Stig PT mtv1's Avatar
    Apr 2008
    Tipperary
    change the auto to lo
    but tbh all routers (well most)
    you can make the client static so no need to do it in debian config
    network local lan clientlist in mine you can reserve the ip
    V.I.P. Member wilf's Avatar
    Jan 2009
    uk
    spent hours looking into this myself, dont waste your time do as the others do. use router!
    Nov 2008
    ireland
    Default static IP
    [quote=digicon;1830416]I tried this when i ran debian 6 and it never worked, i did read that it can cause issues so i went with the advice od setting the static ip in the router itself. Just a Thought[/quo
    Thanks guys for your reply's.
    I use a lynksys WAG 120N router which I understand does not have the option for locking an IP to a mac address. However I can specify a starting IP and the number of addresses to issue. Maybe this will sort things out for me.
    Thanks all.
    Nov 2008
    ireland
    Thanks digicon,
    My router is a Lynksys and this does not support dhcp reservation so I am snookered. I need to lock the IP on the PC. To clarify if I browse to etc/network/interfaces and see my IP settings etc. I change the dhcp to static, save and reboot. I can then ping the PC but cannot access the internet.
    Thanks in advance.
    digicon's Avatar
    Hi Philly,
    As i say i tried on mine and it created problems so mine is done through the Router, Not sure if you can do it on yours but i would have thought 99% of routers allow an IP allocation.
    You could try the Wiki guide to set the static IP:
    NetworkConfiguration - Debian Wiki
    Nov 2008
    ireland
    Hi Philly,
    Thanks digicon,
    I checked out the Wiki guide before. My settings are the same but for some reason when I set to static my internet is lost. Would this have something to do with DNS. Apparently the Lynksys wag120N although a very reliable unit does not support IP allocation.
    Just in case it makes a difference Network Manager is installed on my system.
    GastonJ's Avatar
    What's the results of:
    ifconfig
    netstat -rn
    cat /etc/resolv.conf
    Nov 2008
    ireland
    Quote Originally Posted by GastonJ View Post
    ifconfig
    netstat -rn
    Hi GastonJ,
    Here are the net details etc.
    eth0 Link encap:Ethernet HWaddr 00:0d:61:82:be:e0
    inet addr:192.168.1.101 Bcast:192.168.1.255 Mask:255.255.255.0
    inet6 addr: fe80::20d:61ff:fe82:bee0/64 Scope:Link
    UP BROADCAST RUNNING MULTICAST MTU:1500 Metric:1
    RX packets:287756 errors:0 dropped:0 overruns:0 frame:0
    TX packets:226312 errors:0 dropped:0 overruns:0 carrier:0
    collisions:0 txqueuelen:1000
    RX bytes:22771698 (22.7 MB) TX bytes:24591878 (24.5 MB)
    Interrupt:19 Base address:0xe000
    lo Link encap:Local Loopback
    inet addr:127.0.0.1 Mask:255.0.0.0
    inet6 addr: ::1/128 Scope:Host
    UP LOOPBACK RUNNING MTU:16436 Metric:1
    RX packets:0 errors:0 dropped:0 overruns:0 frame:0
    TX packets:0 errors:0 dropped:0 overruns:0 carrier:0
    collisions:0 txqueuelen:0
    RX bytes:0 (0.0 B) TX bytes:0 (0.0 B)
    Kernel IP routing table
    Destination Gateway Genmask Flags MSS Window irtt Iface
    0.0.0.0 192.168.1.1 0.0.0.0 UG 0 0 0 eth0
    192.168.1.0 0.0.0.0 255.255.255.0 U 0 0 0 eth0
    nameserver 208.67.222.222
    nameserver 208.67.220.220
    nameserver 89.19.64.36
  13. #13
    Jan 2011
    This should do
    $ nano /etc/network/interfaces
    auto eth0
    address 192.168.1.221
    dns-nameservers 192.168.1.254
  14. #14
    Nov 2008
    ireland
    Quote Originally Posted by binamee View Post
    This should do
    auto eth0
    Thanks binamee,
    I will try your suggestion. I had it as above but I did not have any detail for the DNS.
    Will let you know how it goes.
  15. #15
    Sep 2008
    In a land far, far away
    Thanks binamee,
    Actually, above you had
    Which in itself says to networking to ignore lines after it and do dhcp instead of static IP.
