Results 1 to 13 of 13
Thread: ber
    Member darren08's Avatar
    Nov 2008
    kerry
    Default ber
    hi everyone had channels up to hour ago then they all went have snr and agc readings but no ber can anyone tell me why and more importantly what ber is exactly thanks
    Administrator
    Devilfish's Avatar
    Feb 2008
    BER is Bit Error Rate. If you have a good signal and the SNR is up above 95% then you won't get BER, this is good.
    If you are getting a good signal but channel is blank, its probably a key issue. Go to sky sports one and reboot the box.
    Nov 2008
    kerry
    Default mmds
    still nothing did as you advised 22 transponders with no new services is what it is saying could it be my downconverter?
    Nov 2008
    kerry
    Default signal
    also when i go into signal find they are all reading 0
    DK Veteran tomhick024's Avatar
    Dec 2008
    Between a Rock and a Hard Place
    Are you using Chxxus ariel or the Yagi with the built in downconverter?
    Nov 2008
    kerry
    Default c****s
    with the small c****s downconverter
    Dec 2008
    if chanells disappered all of a sudden and you were not near cables, more than likely the PSU for downconverter died or else the tuner got some sort of spike!
    Try manual scan starting at 218mHZ, going up at 8mHz intervals and see do you get anything!!
    Nov 2008
    kerry
    Default mmds
    what happened was id lost sky 1 sports so i turned the box off plugged it back in and all channels were gone restarted evo cam and tried putting it on sky sports but no channels coming up i was pressing buttons on file mode maybe i ~~~~ed something up there ?
    Dec 2008
    My advise, reflash from scratch and the add roms and au files via ftp, its the only way of knowing you have good image - sounds as if you ~~~~ed up something in the image itself!
    V.I.P. Member despdan's Avatar
    Dec 2008
    Midlands Ireland
    @darren08
    to check if its the antenna take the cable from the dreambox & plug it into the tv then let the tv search for channels you should pickup sky news clear maybe others on the old analog then you will know if its the box or antenna
  11. #11
    Nov 2008
    kerry
    Default tv scan
    nothing coming up on tv scan
  12. #12
    Dec 2008
    Midlands Ireland
    Quote Originally Posted by darren08 View Post
    I would say its the antenna if you got nothing.
    Check all the cables.
    Make sure you are powering the antenna.
    what are you snr agc & ber?
  13. #13
    Nov 2008
    kerry
    Default freq
    cant tell ya i just changed image and now ive lost all my keys etc trying to ftp box but can connect to it im really tormented now need image for here as i cant ftp the box think i need to go away from it it tomorrow in losing my patience with it thanks for the help
