Results 1 to 5 of 5
    mislav88's Avatar
    Mar 2011
    Default T5 EDC16U1 DTC OFF
    I have VW T5 with 1.9TDI AXB engine, EDC16U1 ECU.
    I need to turn off DTC 16622 or P0238
    Quote Originally Posted by mislav88 View Post
    What's a reason?
    Switching off error "high signal of pressure sensor" will not solve overboost problem.
    mislav88's Avatar
    Mar 2011
    got a request from mechanic who is doing that car, he changed MAP sensor and wiring to ecu, car now runs fine but throws this error and mil on dash
    New sensor is 2.5 bar original sensor or he used another sensor for lower max pressure, for example, 2.0 bar sensor ?
    NP to switch off error and MIL, but better use proper sensor or at least use 3.0 bar sensor and recalibrate signal in dump.
    Just for test - but it's incorrect solution
    Pass in PM
    mislav88's Avatar
    Mar 2011
    at the end car came to my garage, problem were bad pins in ECU connector, changed them and everything works fine with stock file
    thanks for help about dtc off anyway
