npepo (18th December, 2013)
hello , have a sid204 ECU from Jaguar 2.7 v6 diesel with DPF full on dash .I am reset dpf and success regenerate.Car is ok now , no DTC but if someone have good expirience and good solution for DPF off will be great .
thanks in advance !
try and report back!
Pass in PM.
Get push THANKS on right side button . . . . and add
zoro1 (1st October, 2014)
i will check it , thanks!
And regeneration is off???
How many miles to the masses last regeneration?
Hi, I need to delete the Fap for Jaguar with Sid204 ECU. I have eliminated EGR but for Fap I cannot find a working solution. Can you help me? I attach Ori file and EGRoff tested file
hi
i have jaguar xf sid ecu need egr off dpf off vehicle in limp mode dpf error
please assist sid (1).rar
thank you in advance
hi post here just flash file size must be 2mb
<a href="https://www.evc.de/en/check_evc_license.asp?k=JETn6EjRQpeE9y4%2fKKRgkQ%3 d%3d" target="_blank"><img src="https://www.evc.de/common/check_evc_license_image.asp?k=JETn6EjRQpeE9y4%2fKK RgkQ%3d%3d"></a>
hi sorry here is the file sid (3).rar
thank you
hi posted just flash as requested please assist
thank you
