nobody can help me?
nobody can help me?
obnchip: your solution is working? I made very similar modification and after 10km I got error.
Its must works.try it.have you modified the 2 block's?
I modified only the second block.
Mybay mishu_b is right - can you send me corect midification?
I think this is corect EGRoff for this car.
try this file - report results!
Br
PM for good solution...
BR,
pawliukazz
I still have problem with EGRoff on this car. I tried modification by mishu_b (I think is the same modification like do Volta) and after 20km get error P0405 "EGR position sensor low voltage". Is there any other solution?
Not looked, but the above solutions are probably hysteresis flow solutions. If you have an electrical issue, then you need something different, that you're not going to get for free.
Pro VAG Petrol Tuning | Pro DPF Removal | MED17 TPRot Removal
Hello VOPI.
Try my solution and report checksum ok
IF YOU THINK IT'S EXPENCIVE TO HIRE A PROFESSIONAL,WAIT UNTIL YOU HIRE AN AMATEUR
Again, for good 100% good solution contact me... no error will be displayed. Not the first time i'm doing it...
Regards,
pawliukazz
