Page 1 of 4 1234 LastLast
Results 1 to 15 of 59
    Jan 2013
    Angry USBLoaderGX "Exception (DSI) occurred"
    Hi guys
    I have problem with USBLoaderGX "Exception (DSI) occurred". My installation procedure HBC:
    - LetterBomb
    - DOP-Mii v16
    - IOS236_Installer_v6
    - cIOSX_rev21-Installer
    - USB LoaderGX (version 3.0 r1180) by "USBLoaderGX_Installer_v1.8.exe"
    Installation was ok, but when I back up my games to HDD with USB LoaderGX, my Wii was running 2 seconds and error message came up "Exception (DSI) occurred"
    After 20 seconds USBLoaderGX kick me back to their main page. I do not know what I've done wrong. And what to do. Please help me.
    sysCheck v2.1.0b19 by Double_A and R2-D2199, Nano
    ...runs on IOS58 (rev 6176).
    Region: PAL
    System Menu 4.3E (v514)
    Drive date: 2007.02.13
    Homebrew Channel 1.1.0 running on IOS58
    HomebrewFilter ist nicht installiert
    Hollywood v0x11
    Console ID: 115512241
    Boot2 v4
    Found 68 titles.
    Found 45 IOS on this console. 12 of them are stub.
    IOS4 (rev 65280): Stub
    IOS9 (rev 1034): No Patches
    IOS10 (rev 768): Stub
    IOS11 (rev 256): Stub
    IOS12 (rev 526): No Patches
    IOS13 (rev 1032): No Patches
    IOS14 (rev 1032): No Patches
    IOS15 (rev 1032): No Patches
    IOS16 (rev 512): Stub
    IOS17 (rev 1032): No Patches
    IOS20 (rev 256): Stub
    IOS21 (rev 1039): No Patches
    IOS22 (rev 1294): No Patches
    IOS28 (rev 1807): No Patches
    IOS30 (rev 2816): Stub
    IOS31 (rev 3608): No Patches
    IOS33 (rev 3608): No Patches
    IOS34 (rev 3608): No Patches
    IOS35 (rev 3608): No Patches
    IOS36 (rev 3351): Trucha Bug, ES Identify, NAND Access
    IOS37 (rev 5663): No Patches
    IOS38 (rev 4124): No Patches
    IOS40 (rev 3072): Stub
    IOS41 (rev 3607): No Patches
    IOS43 (rev 3607): No Patches
    IOS45 (rev 3607): No Patches
    IOS46 (rev 3607): No Patches
    IOS48 (rev 4124): No Patches
    IOS50 (rev 5120): Stub
    IOS51 (rev 4864): Stub
    IOS52 (rev 5888): Stub
    IOS53 (rev 5663): No Patches
    IOS55 (rev 5663): No Patches
    IOS56 (rev 5662): No Patches
    IOS57 (rev 5919): No Patches
    IOS58 (rev 6176): USB 2.0
    IOS60 (rev 6400): Stub
    IOS61 (rev 5662): No Patches
    IOS62 (rev 6430): No Patches
    IOS70 (rev 6912): Stub
    IOS80 (rev 6944): No Patches
    IOS236[36] (rev 65535, Info: rev 3351): Trucha Bug, ES Identify, NAND Access
    IOS249[58] (rev 21, Info: rev 21): Trucha Bug, NAND Access, USB 2.0
    IOS250 (rev 65535): Trucha Bug, NAND Access, USB 2.0
    IOS254 (rev 65281): BootMii
    BC v6
    MIOS v10
    Report generated on 2013/01/10.
    Forgive the bad english.
    I am very....
    Jan 2013
    Is there no one who can help me with this... ???
    DK Veteran Keithuk's Avatar
    Aug 2010
    England
    I've seen this talked about before have you Google it?
    They say just remove the files of the SD card and download the new version and install it.
    Looking at that sysCheck you haven't install much.
    Download d2x v8.0 final wad pack and install them with Multi-Mod-Manager (MMM) v13.4
    While you're downloading download PriiLoader 0.7 and install that. You have talked about uninstalling PriiLoader in your other thread.
    If you want to remove the other stubs shown in the sysCheck download my wad pack and add them to the wad folder on the SD card and install them with MMM.
    Keith
    2010 Golf GTD (170)
  4. The Following 2 Users Say Thank You to Keithuk For This Useful Post:
    coolmedo (5th October, 2013), dvnt568wii (8th February, 2014)
    Jan 2013
    Thanks Keithuk !
    Yes, I have searched google for days, but I did not find it.
    You said "remove the files of the SD card and download the new version.". If I'm not wrong so my Letter Bomb, DOP-Mii v16, IOS236_Installer_v6, cIOSX_rev21-Install, USB LoaderGX is new version, doesn't it??. If not then what is old??
    Do you think I should just install "D2X v8.0 final wad pack" without changing anything on my current softmod, right ??
    Do you think I should remove all stubs or only some of them ??.
    I'm totally new with softmod and in here, you know.
    Aug 2010
    England
    It should have put apps\usbloader_gx folder and may be a config folder on the root thats were it stores all settings and game pictures. Delete them both and dowload the
    USBLoader_GX_V3_0_AllinOnePackage_IOS249.zip and add it to the SD card.
    usbloader-gui - USB Loader GX: GUI for Waninkoko?s USB Loader (based on libwiigui) - Google Project Hosting
    You need to install D2X v8.0 final wad pack as that is needed for the new USB Loader GX.
    Google USB Loader GX "Exception (DSI) occurred" you have to spell it correctly.
    Keith
    2010 Golf GTD (170)
    Jan 2013
    Ok, I'll try as you say and let you know later.
    Jan 2013
    Hi Keithuk!
    I found the Custom IOS Uninstaller v1.0. Is it good to use??
    Aug 2010
    England
    You shouldn't need any uninstaller just install all 7 wads in D2X v8.0 final wad pack.
    Keith
    2010 Golf GTD (170)
  10. #9
    Jan 2013
    Hi Keithuk!
    I try to use "System Menu Hacks" but it says not found "hacks_hash.ini ". In priiloaderv0.7 plus hacks.rar, it has only hacks.ini. What can I do ??
  11. #10
    Aug 2010
    England
    Thats something that missing in the PriiLoader 0.7 download and it isn't in priiloaderv0.7 plus hacks either as you say. I've added hacks_hash.ini in my PriiLoader_0.7_with_ini_files if you want to extract that ini file and you can add it to the SD card root and the priiloader folder then both options are covered.
    Keith
    2010 Golf GTD (170)
  12. #11
    Jan 2013
    I did as you said. Installs "D2X v8.0 final wad pack" and "my wad pack". But, now USBLoaderGX not find my HDD. It counts down 20 seconds. And does not find HDD.
    Then I try to backup a game. It reads disk but says 0.0Gb.
    Region: PAL
    Priiloader installed
    Hollywood v0x11
    Boot2 v4
    Found 74 titles.
    Found 50 IOS on this console. 4 of them are stub.
    IOS11 (rev 16174): Trucha Bug, NAND Access
    IOS20 (rev 16174): Trucha Bug, NAND Access
    IOS30 (rev 16174): Trucha Bug, NAND Access
    IOS40 (rev 16174): Trucha Bug, NAND Access
    IOS50 (rev 16174): Trucha Bug, NAND Access
    IOS52 (rev 16174): Trucha Bug, NAND Access
    IOS60 (rev 16174): Trucha Bug, NAND Access
    IOS70 (rev 16174): Trucha Bug, NAND Access
    IOS80 (rev 16174): Trucha Bug, NAND Access
    IOS245[37] (rev 21008, Info: d2x-v8final): Trucha Bug, NAND Access, USB 2.0
    IOS246[38] (rev 21008, Info: d2x-v8final): Trucha Bug, ES Identify, NAND Access
    IOS247[53] (rev 21008, Info: d2x-v8final): Trucha Bug, NAND Access, USB 2.0
    IOS248[55] (rev 21008, Info: d2x-v8final): Trucha Bug, NAND Access, USB 2.0
    IOS249[56] (rev 21008, Info: d2x-v8final): Trucha Bug, NAND Access, USB 2.0
    IOS250[57] (rev 21008, Info: d2x-v8final): Trucha Bug, NAND Access, USB 2.0
    IOS251[58] (rev 21008, Info: d2x-v8final): Trucha Bug, NAND Access, USB 2.0
    BC v6
    MIOS v10
    Report generated on 2013/01/12.
    What should I do ???
  13. #12
    Aug 2010
    England
    There are still a few things missing from the IOS's. Download Full Cios wad pack that will install 202, 222, 223 and 224 don't bother with the d2x v8.0 as you've already installed those.
    As for the drive not being recognised what size drive are you using and is it a mains powered USB drive? There are threads on here http://www.digital-kaos.co.uk/forums...ind-hd-253429/ have a read.
    Keith
    2010 Golf GTD (170)
  14. The Following User Says Thank You to Keithuk For This Useful Post:
  15. #13
    Jan 2013
    I got error:
    Installing 1/1: cIOS202[60]-v5.1R.wad - Ticket (-2011)
    Final status - 1 did not complete.
    Installing 1/1: cIOS222[38]-v4.wad - Ticket (-2011)
    Installing 1/1: cIOS223[37-38]-v4.wad - Ticket (-2011)
    Installing 1/1: cIOS224[57]-v5.1R.wad - Ticket (-2011)
  16. #14
    Aug 2010
    England
    Shut down the Wii and startup and try them again.
    Keith
    2010 Golf GTD (170)
  17. #15
    Jan 2013
    Thank you .. thank you .... thank Keithuk. You saved my life. I can backup games and play games now.
    I promised my kids for a long time. Now they are very happy. Maybe there are many techniques that I need your help in the future. Thank you again.
