    Sep 2012
    Default Has anyone swapped cluster on Suzuki swift?
    After swapping cluster there is abs light
    Does the cluster store some coding or something??
    you have to reset abs with some diagnostic tool.
    if you power up car without dash this happens sometime.
    Sep 2012
    Thanks mate, what is procedure to remove needles on these safely?
    twist and pull
    Yes twist anticlockwise in 5 to 6 rounds it is easy but problem is when you put back needles ! but you can fix easily gauges same like w203 see picture..
    I think dash is coded to car i did one a while ago put dash back in and wouldnt start put original file back in and redid job and it was fine
