Results 1 to 8 of 8
    Top Poster Am1n-0s's Avatar
    Oct 2010
    Algeria, Tounane
    Default FAP 607 0281010880 something wrong
    Have removed FAP from 607 ecu 0281010880 using Ecusafe 1.9.3.0
    Car run well, problem is that it can't exceed 170Km/H
    it can be a problem of file ?
    there is no fault in diag !
    Thank's for help
    Did you emptied or replaced the FAP with a straight tube?
    Also sometimes ECUsafe creates conflicts with the torque limiters maps. try disabling that option when making the Fap off file.
    Oct 2010
    Algeria, Tounane
    Yes, i have cleaned the FAP tube,
    I have also removed option torque limiters, it's on red color when doing this function.
    usually you dont disable the torque limiters, unless car has low power
    Oct 2010
    Algeria, Tounane
    I'll try again and let you know, i thaught using the cracked version from ecusafe have some problems !
    Oct 2010
    Algeria, Tounane
    Have tested everything and doesn't work!
    send me ori i can help you
    Oct 2010
    Algeria, Tounane
    Have tried Ecusafe 1.9.3.0 it give better result now car go 190Km/h.
    Thank's everybody
