why do you need a mount?...just use Dcc or FW
ces
ces
humaxdriver...
I guess the only reason to network mount is to make the DM500 acts like it has a HDD, then you can record your movies and play it back from your HDD in the PC through dreambox.
but if you need it to backup your box then you can use many programs you'll find them here in the forum like...
FlashWizard 6.3
Universal DreamUp 1.3.3.4
Dream Control Center (DCC 2.95b)
If u still need to mount please let me know
regards
sorry to cut in but could you tell me how to mount to pc, i have tried everything but still no joy, my os is vista ultimate T.I.A
Use this method and files below.They are hand pdf files that someone once wrote relating to the Eagle-Dreambox clone, I have included ngrab and rename tools for video playback to a Dreambox.
Regards:
Alun
**The Worlds Best Interactive F1 Strategy Game**
Just use Jade Pli really easy on my 500 all done from the web gui and all instructions are on there wiki page
joe2419...
vista is very awful... I tried many times to mount a CIFS but I couldn't, as dreambox can't see it.... this problem always faces me when I'm trying to connect Vista PC to a network, it can't see nor be seen by any pc in the network, but I tried to mount the dreambox with xp and windows 7 and it is working fine with me
I'm using vista ultimate at the moment and on 500 and 800 no problems
Hi cauliflower69 can u tell me how u did it t.i.a
h**p://www.pli-images.org/modules/wiki/index.php?wakka=E1Mount
I followed these instructions m8.
Make sure that the location can be seen as a shared folder.
After you mount it restart the box as I hadn't done that and thought it never worked but after restart perfect
make sure that your stb has a static ip addy then use flash fxp to access it...dont forget he user & password its very simple once you have a static ip
ces
hi i cannot download the pdf file
hi i cannot download the pdf file ????????
how can I mount DM600 so that i can access from my PC (windows) using exploerer ( \\xxx.xx.xx.xx )
Hi all, anyone know if its possible for Explorer to access a 2TB hardisk in a DM 8000 so I can save torrents to it and access them from laptop? That will free up some space on my laptop if utorrent access's the dreambox hardisk rather than a local disk.
Thanks in advance
