Hi mats doday i try read this car with galleto2 but when i get 100% whene i read soft ware give me error and flash not save!
how i can read and write this ecu without risk.
Thank you.
Br.Babos
Thank you.
Br.Babos
Get push THANKS on right side button . . . . and add
Hi! Did you read it by obdII or in boot mode? What model of ECU do you have? It can be found on ECU lable.
me to have problem with read this ecu not save flash
hi ecu is delphy i try read to obd2
ecu and ID i see but when i read i have error
i asking other tuners where is problem and i have report bad conect to obd2 or need do this job to table.
Soon i test this metodic and after report back.
I have tried it on the bench etc, but it does not work.
You will need Ford powergate for this ecu. At this moment I have not found another tool which can flash this Ford ecu.
extra info:
PIN13 - Programming voltage 18V during programming or reading in security mode
PIN15 - SCP -
PIN16 - SCP +
PIN97 +12V
PIN8 +12V ignition
PIN55 +12V Keep alive power
PIN76 PIN77 PIN 103 - Ground
