Page 3 of 3 FirstFirst 123
Results 31 to 41 of 41
  1. #31
    Oct 2008
    hi sorry just seen this, you may need a more upto date image, is it a clone box
  2. #32
    Mar 2013
    any latest news on the iplayer or itv player???? does it work ok on the openpli image?
  3. #33
    Oct 2008
    i think it works on open pli, i use dreambox uk pli image and it was working for me. i think it might be worth waiting for the ondemand plugin to come, itv bbc 4od altogether with others i believe
  4. #34
    Feb 2013
    Hi everyone
    I have just install BBC iplayer and RTEplayer and it everything works fine, the only issue i have is the picture seems to be a bit blurry and picture could do with a bit of resizing to fit on screen. Does anyone know how to do this(couldn't see any options in plugins to do so)?
  5. #35
    DOUGALMCD's Avatar
    May 2011
    Suburbia
    Try fit to screen on tv you have picture size button on tv remote.
  6. #36
    Feb 2013
    Thank dougalmcd, that fixed the screen size issue. do you know how to increase picture quality. the picture can look a bit blurry sometimes?
  7. #37
    Top Poster weedman's Avatar
    Dec 2011
    By my computer
    Lightbulb Install iPlayer & ITV Player on your dreambox 800HD SE
    First, Download the files..
    BBCiPlayer.zip
    ITV-Player-E2-Plugin-master.zip
    enigma2-plugin-extensions-et-livestream_1.0-r0_mipsel.ipk.zip
    Heres the fix for everyone having trouble! (I think!)
    Install the attached `enigma2-plugin-extensions-et-livestream_1.0-r0_mipsel.ipk.zip` file. (If you had problems before, this should fix it)
    Unzip & Copy ITV Player and BBC iPlayer into `/usr/lib/enigma2/python/Plugins/Extensions/`
    You can manually delete `/usr/lib/enigma2/python/Plugins/Extensions/EtLiveStream/`
    (Remove the plugin, We only installed it for the dependencies which we have now!)
    Reboot enigma2 (GUI only).. and voila!
    Hopefully this works for many of you having the same "non-playing" issue!
    The only issue im having is the screen sizes, can any one elaborate on the fix? ie: The image is to big for the screen.
    I tested this on my DM 800HD SE Clone, using this image OpenPLi-2_1-beta-dm800se-20120222-sim210-.nfi
    Notes: I debugged this by telnet'ing to my box, and entering `init 4; sleep 4; enigma2` This will reboot and allow debugging through telnet..
    Then I found this error:
    Gstreamer error: No URI handler implemented for "rtmp". (12) from uridecodebin0
    and then tracked down these dependancies:
    Downloading http://downloads.pli-images.org/feed...1.4_mipsel.ipk.
    Downloading http://downloads.pli-images.org/feed...-r1_mipsel.ipk.
    When installing packages I always use Telnet. If the packaged failed to install the error will be shown immediately in my console which helps in debugging it.
    I got both working on 2 open pli images, and debugging this way was really useful.
    Last edited by weedman; 29th April, 2013 at 11:06 PM. Reason: added image and updated notes
    - Thanks to those who deserve them, and none to those who don't...
    - DM 800 HD - Clone | DM 800 HD SE - Clone | Openbox S11
    - weedman
  8. The Following User Says Thank You to weedman For This Useful Post:
    atlas1888 (18th January, 2014)
  9. #38
    Hi all, Will this fix work on Dreambox 8000 clone E2 1.06 D.E Image
  10. #39
    Senior Member cboyer's Avatar
    Feb 2012
    hiya people im struggling with this? im running SIM2 backup uk OpenPLi-4.0-beta-dm800se #ssl84d + latest dmm drivers and i dont have the path /usr/lib/enigma2/python/Plugins/Extensions. when i get to python i have python 2.6 and python 2.7 then no plugins folder??
    "I've got it made. I've got a wife and a TV set -- and they're both working."
  11. #40
    May 2009
    is there a way this will work on a DM8000 original
  12. #41
    Nov 2013
    Hi,I am not in UK but want to connect via VPN. But before I pay somewhere or do the work I would like to know if you can see live TV. I am asking because it seems to me that it is only "on demand", am I right? I already installed the iPlayer but only see series or programes in the list, nowhere a "watch live" button or something. Can you help? If it is only "on demand" I won?t do the work/pay money for VPN.
