Results 1 to 13 of 13
Hybrid View
    z786's Avatar
    10 Steps Ahead of You
    Exclamation Problem with FGtech and bmw edc17
    hi can some1 tell me what these errors mean plz
    same ecu will not go into boot mode
    "I always tell the truth. Even when I lie"
    "We Taking Over, One City At A Time"
    It has detected TP. It will not go into boot because the TP level is too high for the clone.
    Pro VAG Petrol Tuning | Pro DPF Removal | MED17 TPRot Removal
    z786's Avatar
    im using magpro x17 to put it into boot
    ecu is from a 2008 bmw its a cp02, didnt know it had TP?
    i was just using fgtech for obd flashing
    Quote Originally Posted by z786 View Post
    Its not matter if is 2008 and CP02, if car is updated by dealer then is software newer with TP. Use boot mode, because FG cant made CHK.
    So will it go into boot or not? Will the X17 not flash OBD?
    z786's Avatar
    its not going in to boot
    havent tried flashing it using x17
    z786's Avatar
    somebody must know what CKWR2 must mean???
    z786's Avatar
    Bump .....
    z786's Avatar
    Ecu is not going in to boot either
    ecutuners's Avatar
    Apr 2011
    United Kingdom
    use this boot pad mate
    Kess v2 FW 5.017 full unlimited token - Ktag 7.020 full unlimited token
    ALL EDC17/MED17 EEPROM CHECKSUM + VAG IMMO OFF BY EEPROM - NO SAFE
    EDC16/17 POPCORN - ME7/7.5 ANTI LAG - LAUNCH ALS/NLS
    DPF EGR DTC SCR, Custom Tuning, Damos Translation, FRF / SGO Files
    Professional Engine Software Development
    Babos's Avatar
    Mar 2012
    hi mate for boot mode is very inportant good connects to pin!!!
    i befor do same ecu and have problems after i made good connects and all be fine!
    z786's Avatar
    already tried that boot pin aswel mate
  13. #13
    ecutuners's Avatar
    Apr 2011
    United Kingdom
    Solder the wire directly to the pad instead of using frame mate its a better connection cos that pad is very small
