Results 1 to 11 of 11
    luis12's Avatar
    Jan 2011
    Panama
    Default need read 1K78X 144pin Xprog
    Need help reading this MCU with Xprog, I made wire conections like in instructions but cant read, are any trick for read this MCU?. Need lift any pin?. Dash of Ford.
    Dec 2010
    vietnam
    Quote Originally Posted by luis12 View Post
    try and re post..........
    be so carefull when you doing ford cars whit xprog since i fu(ed up 2006 fiesta im using upa)
    honingkoning's Avatar
    Jun 2010
    Dessert
    No problem with xprog for me, but did you pit external pwr on your xprog.
    And no need for direct soldering on mcu There are solderpoints on your PCB.
    Regards Adam.
  5. The Following User Says Thank You to honingkoning For This Useful Post:
    clauberty (29th June, 2013)
  6. #5
    luis12's Avatar
    Jan 2011
    Panama
    Default MCU
    Quote Originally Posted by honingkoning View Post
    Regards Adam.
    Friend I tryed to read in BDM points and result is ?no BDM conection? if conect like anterior photo starts reading but makes error and only FF and some bytes, do you think that need to lift any pin, Digimaster reads by BDM points but dont read all memory, can you explain me how to input sec bytes in Xprog? Thx.
  7. #6
    Jul 2010
    U.S.A
    Did 2006 escape with same mask(144 pins) by bdm points...I use upa...non secured mcu
  8. #7
    Jun 2010
    Dessert
    Just select your mcu in xprog menu There is sec and unsec and xprog finds sec bytes automatic.
    Regards Adam.
  9. #8
    luis12's Avatar
    Jan 2011
    Panama
    Regards Adam.
    Thanks Bro you were right, imagine i didnt make it right first time for my inexperience with Xprog but like you said, selected secure and readed eeprom and flash, only some times gives error but if you insist Xprog reads fine, Thx.
  10. #9
    Jun 2010
    Dessert
    Why you read flash, eeprom is enough for milleage.
    Dont take the risk for corrupting flash data.
    Regards Adam.
  11. #10
    luis12's Avatar
    Jan 2011
    Panama
    I know the Kms are in eeprom, but testing conection and because was imposible make read in eeprom i decided to select: read flash and Xprog begins reads, until it was imposible (dont know why) perhaps it unlocked MCU, what do you think?
  12. #11
    jcgabbi's Avatar
    Sep 2009
    Brazil
    Hello...
    Select MC9S12-EEPROM (like picture) and use BDM board for 9s12 processors.
    Good luck!
  13. The Following User Says Thank You to jcgabbi For This Useful Post:
    Talleresmalaga (15th October, 2020)
