Page 10 of 17 FirstFirst ... 56789101112131415 ... LastLast
Results 136 to 150 of 253
  1. #136
    Nov 2014
    hello mates,
    i have xprog M,It says communication error.
    i download this xprog repair and repair my xprog now its says.
    DEVICE IS SILENT NO LIGHT FLASH OR BLINK ON THE XPROG.
    HAVE CHECK THE ENVIROMENT AND CHOOSE THE RIGHT USB PORT.
    any help.
    thanks,
    best regards.
    PC.
  2. #137
    Mar 2015
    hi my friens please i also want a tutorial to repair my clone but i can not dowload the tutorial you are posteg please help me i want this solution
  3. #138
    Feb 2013
    hi
    My xprog is 5.50
    everything installed fine
    Error reading eeprom and mc
    want to upgrade, how to solve?
    sorry for my English
  4. #139
    serg2000's Avatar
    Apr 2011
    Ukraine
    Talking
    558 is aviable
  5. #140
    Feb 2013
    Chinese clone is
    update = blockade
    how to solve?
  6. #141
    May 2015
    argentina
    hello serg2000
    I need your help.
    My English is not very good.
    my xprog asks me to register my hard .
    and is a Chinese clone .
    How I can make it work ?
    ls version that I have is the 5.50
    place another previous firmware versions .
    when I want to read a device, asking me to update it.
    once asked me updated record hard .
    I have the upa 1.3 with which the firmware eh recorded in the hard id guines I just listed .
  7. #142
    Holtek's Avatar
    Fatal Error #14391 mean that the ATmega64 in the Xprog is not secured (lock bits LB1, LB2 is not programmed) so hardware registration in this case impossible.
    Only way is use any ATmega64 programmer, write lock bits LB1, LB2 and retry xprog registration.
    Best regards.
  8. The Following 2 Users Say Thank You to Holtek For This Useful Post:
    pablobonome (26th May, 2015), Yuri_L777 (11th December, 2022)
  9. #143
    May 2015
    argentina
    Hello , I'll try .
    thank you very much
  10. #144
    May 2015
    argentina
    Hello friend !!! HoltekI worked !!!
    tranks!!!
  11. #145
    May 2015
    argentina
    hi , how are you?
    Certificade update what is ?
  12. #146
    episcop's Avatar
    Portugal
    Have problem with soft 5.51 don't start... Starting, have screen with logo Luis Andre, starting loader, decripting, running....and Windows close programm with error. Win7-32bit, antivirus 360"-off
  13. #147
    May 2015
    argentina
    hi , the x -prog now works even with antivirus .
    My question is this :
    if I click then updated certificate , you can return block x -prog ?
  14. #148
    episcop's Avatar
    Portugal
    I don't update this, after writing atmega(flahs, eeprom, fuses, lockbits), and start soft by Luis, update firware of xprog and all recognised whell, If you interesting this "faso isso amaha" and post.
  15. The Following User Says Thank You to episcop For This Useful Post:
    pablobonome (31st May, 2015)
  16. #149
    Quote Originally Posted by episcop View Post
    Are you using Adobe acrobat 10?
  17. #150
    episcop's Avatar
    Portugal
    Yes. Using Adobe reader 10.1, bat after instaling 11, problem solved.
