Page 11 of 17 FirstFirst ... 678910111213141516 ... LastLast
Results 151 to 165 of 251
  1. #151
    Apr 2015
    hi all and thanks for this opportunity
    actually i have a problem i have the xprog m v 5.0 and i tried to update it
    so it is dead
    i bought an usbasp s51&avr but also have error power on failed , i have communication with it ay usbasp found on port but power on failed
    i changed the atmega64a and check everything pins out soldering everything
    i connect it to tl866a with 12v power to xprog and cheked everything
    when i press check id it say ff ff ff
    when i try to read it says succeful and also if i say erase it says succeful
    when i try to program it begen to program and then error adress 0x00000 ,buf val 0x0c , ic val 0xff
    can any one explain me please what i did wrong ?
  2. #152
    May 2015
    argentina
    hello, how I can authorize the use of these micros?
    AUTH-0023-1 MAC7xxx
    AUTH-0023-2 XC23xx
    AUTH-0024-1 MC9S12Cxx
    AUTH-0024-2 MC9S12XE
    AUTH-0024-3 9S12XE SECURITY
    AUTH-0024-4 MC9S12HA/HY/P
    AUTH-0025-1 MPC/SPC5xxx Authorized 11/4/2014
  3. #153
    serg2000's Avatar
    Apr 2011
    Ukraine
    Quote Originally Posted by pablobonome View Post
    AUTH-0023-1 MAC7xxx
    AUTH-0023-2 XC23xx
    no problem
    pls wrote in PM
  4. The Following 4 Users Say Thank You to serg2000 For This Useful Post:
    antonypaul (15th June, 2015), boxsport (4th October, 2022), mohamedkey (18th July, 2015), pablobonome (2nd June, 2015)
  5. #154
    May 2015
    argentina
    hello, the system tells me that you do not have space for private messages.
  6. #155
    sawatdee0999's Avatar
    Oct 2010
    Canada
    how can i authorized the use of these
    AUTH-0023-1 MAC7xxx
    AUTH-0023-2 XC23xx
  7. #156
    Member CentralinasPt's Avatar
    Mar 2012
    Portugal
    My XPROG 5:50 worked well, I update and now I can not read HC05, I work a lot with EZS and now to read 1D69j and another reads all the 000000
    Dont Forget To Leave Thanks Alegria Chiptuning
  8. #157
    Oct 2013
    Garage
    I too can help with authorization, but little lower version.
    >5.5... t many problems, unstable software, easy to brick mcu
  9. #158
    Sep 2015
    sorry, but links for update on page 1 don't work...
    check pls
  10. #159
    Sep 2013
    Hello all,
    I have update my Xprog 5.50 chinese that was dead. Now its working like never did, but i dont have any authorizations and update firmware gives an error. What am i doing wrong? Should the update firmware must be througt port R232?
    ZedBull Clone + EFfI - T-300 - Bmw EWS editor - TrueCode - NEC Key programmer - AutoCom CDP+ - Vag.com - Silca 4D Tool - UPA USB Full adaptors + TMS adaptor - minipro TL866 - Piasini - Galleto - Winols 1500 - TunerPro - Tachosoft ImmoCalc - Tacho231 - VAG EDC15P+ Suite - RenaultPinExtractor 2 - Immo universal decoder -3.2 - ecueditor.com for Hayabusa K2-K7, K8-, BKing and Gixxer K7 - Autodata - Galleto 2 - Mpps -
  11. #160
    electronistul21's Avatar
    Nov 2011
    galati,romania
    what version you have first time?
    Carprog 8.21,xprog 5.55,galletto v54,kess and ktag rework
  12. #161
    Sep 2013
    its was a 5.50 but i never manage to put it to work with sucess, so i downgrade it to the fix version in this post.
    Thanks electronistul21
  13. #162
    Sep 2013
    Quote Originally Posted by electronistul21 View Post
    Can you give me the firmware 5.50 plus the SW 5.5 with all the authorizations?
    if i could put it like it was originaly the better
    thanks in advance mate
  14. #163
    Sep 2013
    does anyone can help me? maybe i should buy another one and then fix my damaged one with the SW HW FW?
  15. #164
    Apr 2013
    NO UPDAT FO TOOLS CHINA
  16. #165
    Two good and reliable versions available on this forum, classic v5.0 and v5.5.1 but the later you need to wait for the crack author, serg2000 to activate it. No matter if it's china hw as long it's not defective.
