Page 13 of 17 FirstFirst ... 3891011121314151617 LastLast
Results 181 to 195 of 253
  1. #181
    jakesman's Avatar
    Oct 2013
    Bethlehem Southafrica
    new problem xprog was 5.3 with dongle updated to 5.5.5 but was not very stable and went back to 5.5.1 all good but after time starting to get verify errors and wrong reads so reflashed and something went wrong during the flash wit fuse and lock bits and now device is silent , desolder the eeprom and read it al FFFFF reprogram the eeprom with a dump now xprog identify when i put usb cable but it looks like the atmega is locked or busted , i put 4Mhz ossicillalator on crystal pin of atmega to see if it will wake up but no luck , Should i replace the atmega64a or another way to wake it up ?
  2. #182
    electronistul21's Avatar
    Nov 2011
    galati,romania
    oscilator not is 4Mhz ,is 11,059Mhz.not work with another quartz.this value ist specified in configuration word.
    Carprog 8.21,xprog 5.55,galletto v54,kess and ktag rework
  3. The Following User Says Thank You to electronistul21 For This Useful Post:
    XJTAG (13th March, 2020)
  4. #183
    jakesman's Avatar
    Oct 2013
    ok but how do i wake the atmega chip up , it looks like it had a problem when programing it with the lock and fuse bits ?
    atmega fuse recovery
    hook up an oscillator (not a crystal) to the clock line on the atmega.
    (any freq, usually 4MHZ)
    erase the device with your ISP program, then reprogram the CLSEL fuse.
    The above works 99.99% of the time!
    http://www.edaboard.com/thread131804.html
  5. #184
    Nov 2011
    galati,romania
    yes,i know this program for erase atmega.i dont know for what raison your atmega not wake-up ,after erase,maybe ist broken.i use evrytime for this work upa for programing,and ist very fine.
  6. #185
    jakesman's Avatar
    Oct 2013
    Quote Originally Posted by electronistul21 View Post
    wel i ordered new ones , strange the eeprom i put in another programmer it all read FF FF FF and ftdi chip also no data the whole xprog got wiped clean no lights not reconized by usb nothing , so reprogram eeprom from a dump i got here reprogramed the ftdi chip and now it reconize it when plug in usb but for sure atmega is dead , options , buy xprog repair set $45 and maybe it stil not work , replace atmega $1.00 and reprogram , or new xprog , damm this thing started with verify errors and after reflash it is dead i use TL866A ISP to flash it never had problem even did it with AVR extreme burner so i am sure atmega is not locked but busted
  7. #186
    Dec 2013
    Hi mate
    try erase atmega, (flash & eeprom)
    progarm lock bits all "true"
    program your fuse bit (for xprog)
    program flash memory
    program eeprom
    set lock bit false, false true, true, true....
    and be happy
    report..
    regards
  8. The Following 2 Users Say Thank You to mrtobby For This Useful Post:
    jakesman (22nd October, 2016), jonazizbey (2nd May, 2019)
  9. #187
    jakesman's Avatar
    Oct 2013
    Quote Originally Posted by mrtobby View Post
    Hi mate
    program eeprom
    and be happy
    report..
    regards
    thanx for reply
    with avr extreme burner first time it was good , second time i use it when it start with verify error it give message "incorrect chip selected " like WTF there is only 1 atmega64 in the menu but it did flash and after that it just refuse to connect "fail to switch power" so with avr no go , tl866 isp it ID the chip as 00000 and if i power it the id change to FFFFFF i can erase it and program it like u said all ticked but it stops with error chip not blank but with blank check it is good , u tried thanx mate but this i will keep in mind for future , just gona replace the Atmega chip then i will come back here and report
  10. #188
    Nov 2011
    galati,romania
    is best way to change Atmega.i think is burned,for this is unstable
  11. The Following User Says Thank You to electronistul21 For This Useful Post:
    jakesman (29th October, 2016)
  12. #189
    Jun 2016
    Budapest HUNGARY
    Xprog original ATMEGA64 files
    Reading Xprog box ver.5.7.2 and Xprog box ver.5.7.5
    with original PC software Certification need Authorization only official registration
    restore old version only atmega64 rewrite
    1.chip erase
    2. all fuse bit setting and program...
    3. lockbit all TREE =all 1...
    4. write eeprom block
    5. write flash block
    6. lockbit lb1 lb2=0 False and program...
  13. The Following 6 Users Say Thank You to f2f2 For This Useful Post:
    Brown012 (30th August, 2020), hbalazs (14th June, 2019), JotaB (17th February, 2018), lounadak (15th July, 2022), tareqqasem (17th June, 2018), volthz (21st October, 2017)
  14. #190
    Jun 2016
    Budapest HUNGARY
    I no can Delete post
    Please Delete this post.
    THX
  15. #191
    jakesman's Avatar
    Oct 2013
    Quote Originally Posted by jakesman View Post
    thanx for reply
    ok
    finaly got replacement chip , used avr extreme to program it ver 5.5.5 and also had problem with it then i saw that one lock bit is not correct in the instructions and wow now my xprog lives again and is even better performing than what it use to it is more stable and reads faster than before , maybe they use cheap low quality chips in factory
    Ask a dumb question and become wise for the rest of your life, but act wise and stay dumb
  16. #192
    Nov 2011
    galati,romania
    this thing had to do it the first time without wasting so much time
  17. #193
    Oct 2016
    can someone share 5.7 clone atmega files i brick my device
  18. #194
    Aug 2008
    Quote Originally Posted by kobol View Post
    did you not see 4 posts up???????
  19. #195
    Oct 2016
    yes i see and i read too. it's original 572 and 575 and i need clone 570, did u see different ?
