Page 15 of 17 FirstFirst ... 51011121314151617 LastLast
Results 211 to 225 of 250
  1. #211
    Aug 2016
    i have XPROG V5.6.0 with usb dongle.
    I can read a EWS3 without any problems but while writing i get:
    Verify Error
    Device: 0000001DH - FDH
    Buffer: 0000001DH - FFH
    Verify error. Continue?
    Yes, Yes All, No
    Please help, thank you.
  2. #212
    Aug 2016
    i found this here:http://obdii365.bravesites.com/entri...e-verify-error
    only it is the other way around with me. with me the error is not when reading but after is has written.
  3. #213
    Jan 2013
    italy
    Emmy, I don't know how's with ews3, but I think that if you kept your wires/connections as short as possible and use an external power supply you might have an issue with the stability due to voltage regulator or something similar. my2cents.
  4. #214
    electronistul21's Avatar
    Nov 2011
    galati,romania
    In this case not import what is long wire.But is very important soldering in corect post to PCB.Open documentation and you can see wher need soldering.Xprog read and write EWS 3 without external supply.
    Carprog 8.21,xprog 5.55,galletto v54,kess and ktag rework
  5. #215
    May 2014
    Hi, i try to update xprog 5.0 to 5.5.1, read first atmega64, but dump from eeprom and flash maybe corrupted or wrong. attach both files to compare. Thanks
  6. #216
    Newbie carminedamolide's Avatar
    Feb 2019
    Italia
    Hi, can you give me the link of the guide?
  7. #217
    Nov 2011
    galati,romania
    search in to forum and find thread of mister Luis Andre.In this post you have all you need,eprom,flash ,lock bits and fuse bits,and connection with UPA programmer.
  8. #218
    Jul 2017
    hi user2468, and all colleagues
    i have xprog 5.72 clone without dongle, my tool has problem verify. please can you help me? the tutorial doesn't open.
    best regards
  9. #219
    Member enriqxxx's Avatar
    Jan 2011
    venezuela
  10. #220
    Oct 2018
    i have new 5.55 and i want to fix a old 5.0 back, i cant read atmega64 xprog shows error comunication 1
  11. #221
    Nov 2011
    galati,romania
    @Shusun you have UPA?is more easy for read and write Atmega 64.
  12. #222
    Mar 2016
    fake not work
  13. The Following 2 Users Say Thank You to PaoloDigital For This Useful Post:
    beongo (13th January, 2020), boxsport (4th October, 2022)
  14. #223
    Aug 2019
    Hello . I unexpectedly hit the update and now xprog is not working .
    I do not remember what software version was before , there is no difference which repair to use ?
    I unexpectedly hit the update and now it is not workingI unexpectedly hit the update and now it is not workingI unexpectedly hit the update and now it is not working
  15. #224
    Nov 2016
    How can reparing my xprog 5.74.
    Poslano sa mog SM-G950F koristeći Tapatalk
  16. #225
    Oct 2014
    Latvia
    Hello, maybe someone can activate my xprog 5.7.5? i changed laptop (old one dead) and cant activate xprog, i bought it half year ago and seller not responding anymore. does someone have any idea how to activate? by the way in attachment reg. request. thanks!!
