pocinas (22nd September, 2019)
Yes made this mistake to update.
Can i Downgrade to 5.5.1 with an other xprog or do I need to remove atmega64 ?
Hey guys, link is dead. Can you help me pls, I have the same problem. I've updated it and now It is not working.
Hi to all DK members, my Xprog is giving me problems, it opens and when I try to read, it opens the window and says WAITING CERTIFICATE. And the bar moves on and on but nothing happens. I have tried to re-install it and it still the same. It's the version 5.84. What is the solution to this error?
Hello, guys, does anyone have, Xprog V5.7.5 software?
Sorry guys, this software is not needed,I was misled by this post, https://www.digital-kaos.co.uk/forum...=1#post2900096 there eeprom from version 5.5.1
certificate in EEPROM Atmega64
If it helped you press THANKS + REPUTATION
Hi, mates
I have a problem with my xprog adapters sometimes I have to unplug a few times and plug it in again for xprog to see them. This is a common clone problem ?
On main PCB i soldered header again still the same issue, I'm thinking of replacing the Atmega IC.
SOLVED: Bad soldering on Atmega.
Keep in mind, English is not my native language.
friends xprog6.26 dongle is blocked Is there a fix software for this version?
hi
lm use xprog 6.26 end have problem with certyficate, use software 6.26 in other laptop its this same problem. lm no update.IMG_20230131_121107.jpg IMG_20230201_134745.jpg
How do you uninstall old versions of Xprog??
Sorry link not working and not open.
Not opened link
