don't know how match shots, but what you mean?
If my post was helpful than Please don't forget to press the Magic word
After new reflash and if the counter remain it can allow 208 shots of read and/or write with good results. When the counter reaches zero you will experience the same as it was. Btw, I can try your dumps by myself and monitor the counter but still no time![]()
user2468 (12th April, 2013)
i think counter is in eeprom in Offset 82 = D0h dec 208
you are telling if i set this to 0 xprog will do verify error?
Yes, on v5.0
FYI v4.5 has no the counter!, FFh and never change
the sulution was with counter, in this update counter is fixed.
Zmann (12th April, 2013)
Ok I will try
i try install NEW5.0.exe and always got this error,
uninstall all previous version, but always the same error.
How i can completely remove xprog ?
format c:
immarius (13th April, 2013)
anyboby have xprog-m 4.5 firware hex full, i want,5.0 have verfiy problem,no good!
last time in d,k find is without arm,
if follow this tutorial you will repair your xprog without verify error
http://www.digital-kaos.co.uk/forums...ml#post1935212
hi,user2468,i have download this link use upa write my xprog-m,is work with 5.0.but have verify problem with read bmw cas3 9s12xdp512,read no locked mecu is no have verify ,use 4.5 read is no this problem.
you have 4.5 full firware hex? i have without arm,cdc-23xx,i want full,thanks!
no i have not 4.5, but to me work fine no verify error, i think you are missing something, download this updated version of tutorial
maybe you use my first tutorial who was with counter. Try to download again my updated tutorial counter fixed now. i read and write cas3 secured no problem eeprom and flash, after this update.
I tested your dump. Sorry, don't know why I stiil see the counter keeps counting down.
Hi Zmann may be if you lock Atmega procesor, counter will go off.
Zmann (15th April, 2013)
