New software version is available for original X-ProgBOX users.
V5.0.0
Added new devices...
V5.0.0
Please upload version 5.4.9
eldb XPROG
I can say nothing but thanks
I haved working v5.0 (metal case) xprogm but when I programming some HC9S12 processors I have verify error.
Well, yesterday I update ATmega64 with flash and eeprom from this post.
And when switch fuses and LockBits like on this pictures i have "Device is silent" and XprogM is dead(RS232 and USB)
But, when I enable Fuse "Watchdog" and program to Atmega64, my xprog is detected in program, but no any information and authorisations.
Now i have no any authorisations and no any data in info (see pic).
Please any help or ideas?
Needs to program 93c46 ? 93c46 its only for USB connection?
SOLVED!!!
My shitty ISP programmer (Propox ISPcable II) always program fuse "Boot reset vector enabled (default adress=$0000);[BOOTRST=0)", even if I unmark this fuse.
I use other XprogM and all programmed ok.
I need to buy a better ISP Programmer
hi
any one have dump for x-prog 5.3 or 5.4
Hi guys I try to update the firmware in the my clone xpog with edbl software 5.50 and after success update when run xprog 5.0 software says message device silent
Please how I can to back again to previews state.
I have and other original xprog but I can to reflash with this tool the atmega 64 from updated (damaged) clone xprog
Thank you for all the info!
So there're still no 5.4.5 or 5.4.8 dumps?
Please tell how to take dump, i can try?
Hello,image rescued Xprog programmer tl866a
the best thing is to set Fuse
Fuse low byte:0x2F
Fuse high byte:0xCA
Extended fuse byte:0xFF
Lock bit byte:0xEB
To load both files together with the set Fuse byte
sorry my english
ecufix (19th September, 2023)
lock bits not correct
2 xprog program this lock bits,all work perfect
My xprog-m clone which I had with dongle v5.3 had problem reading MPC processors, always got stuck on "initialising device". I downgraded to v5.0 without dongle and then it was working fine. Suddenly i started to get the "verify error" problem so i thought solution was to use dumps from 1st post in this thread. Since changing firmware to the one in the 1st post of this thread I can no longer read MPC561 as I always get "initialising device". I can read eeproms fine. I saved original eeprom data but (stupidly) forgot to save original flash data. Anyone able to shed some light pls?
All options are authorized
Last edited by looly; 13th March, 2014 at 01:43 PM. Reason: Additional info added.
Just a note, you probably didn't get the correct data when you read the "original" eeprom/flash as it's protected (and the software checks that it's protected before continuing work).
